won't start - Mustang Evolution
Old 05-17-2012, 05:25 AM   #1
sick5point0's Avatar
won't start
I have a 93 LX hatch that won't start need help I have gas fuel pump n filter is good I have spark fuel my injectors are clicking it cranks over but don't start it only starts with starting fluid n stays on for literally 2 seconds
sick5point0 is offline   Reply With Quote
Old 05-17-2012, 05:38 AM   #2
93slowstang's Avatar
The pump may be just priming and not giving any fuel pressure while you're cranking it.
Old 05-17-2012, 05:41 AM   #3
Yeah but there's this little nipple thing that looks like a tire valve stem when i push the nipple in a lot of fuel is coming out though
Old 05-17-2012, 05:47 AM   #4
Then your injectors may noy be pulsing. Check injectors with a noid light. It could also be the pip/hall sensor.
Old 05-17-2012, 05:49 AM   #5
^what he said.
Old 05-17-2012, 05:50 AM   #6
By pulsing u mean clicking cause when i turn my key to where on my lights turn on in my dash my injectors click n yeah maybe ur right bout the pip/hall sensor have to check it
Old 05-17-2012, 06:00 AM   #7
They should get a signal to fire at certain intervals every revolution or what. I'm not exactly sure of how it does it does it. But the pip sends the ecu the signal for the injectors to pulse( open and close).
Old 05-17-2012, 04:03 PM   #8
Re: won't start
Check your fuel pressure my 95 mustang was doing the exact same thing changed regulator prob fixed
95 black vert is offline   Reply With Quote
Old 05-17-2012, 09:43 PM   #9
Jkgravy's Avatar
Just because fuel is coming out doesn't mean it has pressure behind it, it doesn't hurt to go buy a fuel pressure gauge. You will always have it and you can know what kind of pressure you are getting.
Jkgravy is offline   Reply With Quote
Old 05-17-2012, 09:45 PM   #10
it is a good idea to check pressure. but if he is getting some fuel, which he is it would at least fire. at least i would think. but yes check pressure.
Old 05-18-2012, 09:14 AM   #11
Jkgravy's Avatar
I had the same issue on a 89 and I was getting fuel, and it would start the die right away, I wasn't getting enough pressure to keep it running. Found out it was the filter.
07:36 PM
