Cam help - Page 2 - Mustang Evolution
Old 05-18-2012, 07:14 AM   #36
Re: Cam help
But since I have a computer don't have to have a cam that's computer capable? I don't want to buy a cam then it won't work right
Ajsjstang is offline   Reply With Quote
Old 05-18-2012, 08:03 AM   #37
Re: Cam help
Well, you couldn't go to wild with the cam or the factory ECU tune might have difficulty adjusting to it, but if you get what your engine can handle you will be ok.
Old 05-18-2012, 08:11 AM   #38
Forum Car Trader
90GTNovi2000's Avatar
+1.. That's why you see so many letter cams on the street.. I heard ford made them with a chisel and hammer!!! Lol
90GTNovi2000 is offline   Reply With Quote
Old 05-18-2012, 08:19 AM   #39
Stang.racr's Avatar
Lmao
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-18-2012, 09:05 AM   #40
Re: Cam help
So I could put a b 303 or a e 303 without any trouble
Old 05-18-2012, 09:10 AM   #41
WhiteCobra94's Avatar
Yes but every is different , you won't know till its in , you still may need a tune
Old 05-18-2012, 09:24 AM   #42
Re: Cam help
Tune as in computer or what I haven't messed with fuel injection really before so I'm asking
Old 05-18-2012, 10:07 AM   #43
Every car is different in needing a tune also. I know you needed a tune but a 93 is more forgiving than a 94 ecu. But its still possible that he does. I do know a lot of guys get away without it.
And it would be a good idea to check piston to make sure it works.
Old 05-18-2012, 10:37 AM   #44
Now I was told (correct me if I'm wrong) that a CAM that has a Lobe Separation that is close to stock which is 116 degree lobe, will work better with your stock ecu?
Old 05-18-2012, 10:44 AM   #45
Stang.racr's Avatar
That's what I've always heard
Old 05-18-2012, 10:46 AM   #46
Yeah. I would think the closer the better.
Old 05-18-2012, 10:47 AM   #47
Re: Cam help
That's probably correct.
I can understand how it would be easier for the ECU to adjust the tune for it.
Old 05-18-2012, 03:31 PM   #48
93slowstang's Avatar
Stock is 112* lsa, anywhere between 108-116 is recommended for cars with ecu's. Higher number being easier on the ecu.
---------- Post added at 04:31 PM ---------- Previous post was at 04:27 PM ----------
Since there isn't any ecam love so far, here's my e303. I do have a tune on in the video, it's lumpier without it. May shoot another one with it off.
http://youtu.be/NNNCLV_K3BM
Old 05-18-2012, 03:37 PM   #49
http://www.stangnet.com/mustang-foru...-specs.735867/
Old 05-18-2012, 03:52 PM   #50
That sounds good. It actually sounds more lumpy than my buddies 351 does.
---------- Post added at 04:52 PM ---------- Previous post was at 04:51 PM ----------
It looks like we might be in need of a cam sound thread, like the exhaust threads.lol
Old 05-18-2012, 04:42 PM   #51
Sorry, realized I worded waaaay wrong, had actually just read 115 before I posted. I've got a lot going on over here
---------- Post added at 05:42 PM ---------- Previous post was at 05:19 PM ----------
I am in the process of setting up my exhaust for cutouts so the mid pipe is disconnected from the down pipes right now. I love hearing each side pop on each side vs through a crossover mid pipe.
Old 05-18-2012, 06:17 PM   #52
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
That makes me want to throw an E cam in my 90! Sounds awesome, I love the lope!
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 05-18-2012, 07:19 PM   #53
Thanks, I realized a while back that I could change how it loped with a turn of the switch, still has a hint of the intended lope if you listen carefully.
Old 05-18-2012, 07:23 PM   #54
what do mean? by your chip?
Old 05-18-2012, 08:47 PM   #55
Yes the chip, the lope changes with the timing and idle. So if I set it one way I can have the classic e303 lope, or change the timing and idle and it sounds a little more choppy like in the video.
Old 05-19-2012, 06:06 AM   #56
Nice. Mine will lope a lot more once the idle kicks down. When I first start it its more around 8-900 then it will kick down to about 600 when its warm. It sounds pretty good at 600. But that's the lowest I want to take the idle to because when I go lower it stumbles a little bit when I let off and push in the clutch after a good romp.
10:38 PM
