Cam help - Mustang Evolution
Old 05-17-2012, 08:51 AM   #1
Cam help
Whats the biggest cam u can put in a 93 mustang without doing machine work I heard its the b303 or the e303 need help fast so I can get a cam
Ajsjstang is offline   Reply With Quote
Old 05-17-2012, 09:56 AM   #2
Forum Car Trader
90GTNovi2000's Avatar
The stock springs are rated up to a .550 lift I wouldn't push. It's best to get a cam that supports your other mods.. Considering you have stock heads either the bcam or ecam would work great
90GTNovi2000 is offline   Reply With Quote
Old 05-17-2012, 10:50 AM   #3
I would go with the e-303 it has a better sound to me.
Flamming notch is offline   Reply With Quote
Old 05-17-2012, 11:00 AM   #4
Forum Car Trader
That's a highly debated quote I personally like the b cams with the right exhaust combo
---------- Post added at 12:00 PM ---------- Previous post was at 11:58 AM ----------
This is my b cam with pypes violator mufflers and x pipe..
While on YouTube search Hayden7685 that's my old 85 had a b cam with 40 series flows..
Old 05-17-2012, 11:01 AM   #5
Titus Wadicus
svtlx's Avatar
Re: Cam help
i believe x cam is the largest alphabet cam you can go on stock heads and 302HO pistons...
a "z cam", which i dont think they make anymore (dont quote me on it) would require fly cutting the pistons.
i would stay with "e" or "f" unless u are building a race car. anything larger will have your powerband pushed way up the rpm ladder and pretty useless for street driving unless you dont value your drivers license.
and you definatley need to swap valve springs for anything over 100k mi.
im not real positive on the 550 lift rating on stock springs though per novi2000 suggestion.
regardless, anything over an "b" cam will quickly wear out stock springs that have 100k mi. or more.
and i highly recomend u swapout the spings when you do the cam... valve floating is a super annoying experience.
hope this info helps a bit.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-17-2012, 11:08 AM   #6
Forum Car Trader
+1 on the springs.. It's fairly simple to replace them and springs aren't very expensive. Just get in summit or Jegs and get you some comp springs. Also a simple rebuild of the heads is cheap.
Old 05-17-2012, 11:21 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Cam help
+1
Old 05-17-2012, 03:16 PM   #8
89 5.0 stang's Avatar
Search ...b 303 cam...on YouTube.. prepare to poop yourself!!!!!
89 5.0 stang is offline   Reply With Quote
Old 05-17-2012, 03:27 PM   #9
Here ill save you the time with my low qualit cell video.
Old 05-17-2012, 04:39 PM   #10
I just pooped my pants!!!
Old 05-17-2012, 04:40 PM   #11
Lmao
Old 05-17-2012, 05:16 PM   #12
Stang.racr's Avatar
I would go with a Anderson or trick flow stage 1 cam. I had a e cam and it has .498 lift. You could get away with stock valve spring but if you got a couple hundred bucks get the upgraded trick flow double beehive springs. With that much lift you stick springs could fatigue and float over time. I am in no why picking on a abc cam just saying they are better ones now days.
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-17-2012, 05:20 PM   #13
WhiteCobra94's Avatar
Trick Flow stage 1 cam
Old 05-17-2012, 05:21 PM   #14
Can you post a video???
Old 05-17-2012, 05:29 PM   #15
This is mine , edelbrock heads & intake with Trick Flow stage 1 Cam!
Old 05-17-2012, 05:32 PM   #16
Stang.racr's Avatar
Nice video man
Old 05-17-2012, 05:57 PM   #17
Originally Posted by Stang.racr
Nice video man
Thank you!
Old 05-17-2012, 06:03 PM   #18
Thank you!
Thanks for showing up us letter cam guys.lol
Old 05-17-2012, 06:45 PM   #19
Re: Cam help
X303
Old 05-17-2012, 07:06 PM   #20
Originally Posted by Trojan Horse
i couldnt see that one. it said something about being a member. i tried on my ipad and phone. my phone is pretty capable with adobe and everything.
---------- Post added at 08:06 PM ---------- Previous post was at 08:03 PM ----------
i did forget to mention a few things on mine. this video was done cold. it sounds better once warmed up and the idle kicks down. and also i am running 1.72 roller rockers, which change the idle, not much but a little bit. the 1.72s make the lift .516
Old 05-17-2012, 07:08 PM   #21
Re: Cam help
Try it now, I forgot to use the "Public" link.
Old 05-17-2012, 07:17 PM   #22
click..clank.....clickity clickity clank..... haha. i like it. thats what ou have right?
Old 05-17-2012, 07:32 PM   #23
Re: Cam help
Yep, that's it from 4-5 years ago.
Old 05-17-2012, 07:37 PM   #24
i was pretty sure you did. sounds good.
Old 05-17-2012, 07:52 PM   #25
Forum Car Trader
This is my 2nd fox an 85. Had b303, gt40p heads, 1.6rr, Holley 650, O/R x-pipe 40 series flows.. First 15 secs of video suck lol..
Old 05-17-2012, 07:55 PM   #26
nice. for a minute i thought you were gonna run over the camera! haha
Old 05-17-2012, 08:19 PM   #27
Titus Wadicus
svtlx's Avatar
Re: Cam help
my friend and i both run "e"cams. but he runs 1.6rr and i run 1.7rr we parked both cars side by side, started them, and listened....
you can hear the xtra duration from the 1.7 versus the 1.6. a longer duration between the lopes (if im making any sense). guesse u had to be there lol
i wish we had recorded it. just thought i would ad that so i could particpate in the thread..lol
Old 05-17-2012, 08:30 PM   #28
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I've always heard with a stock 302 it's .512 lift cam with stock rockers, roller rockers you might be able to push a little more. Again just what I've always been told.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 05-17-2012, 08:32 PM   #29
Forum Car Trader
Have you guys ever seen someone stagger 1.6's and it's 1.72's I think I heard that on either e7's or gt40's adds hp.. I was like really??? Confused.. Anyone ever heard of that
Old 05-17-2012, 08:33 PM   #30
What CAM are you talking about?
Old 05-17-2012, 08:34 PM   #31
Titus Wadicus
svtlx's Avatar
Re: Cam help
im at .529 with "e" cam and 1.7's there's room for more. an "f"cam is .542 and there's room for that and still a lil more..
Old 05-17-2012, 08:34 PM   #32
Forum Car Trader
Isn't the .512 the e303 or f303
Old 05-17-2012, 08:34 PM   #33
Pete Jones
Any cam in general, I always hear a .512 lift cam is the biggest you can go with stock heads and rockers.
90 LX hatchback
89 LX Notchback
Old 05-17-2012, 08:36 PM   #34
Titus Wadicus
svtlx's Avatar
Re: Cam help
yup, all your doin is making a split pattern cam so to speak.. ppl do it all the time..
---------- Post added at 08:36 PM ---------- Previous post was at 08:35 PM ----------
ooops... "f cam is .512 .542 is "x " cam
Old 05-17-2012, 09:04 PM   #35
some people go bigger on the exhaust1.7 and leave the intake 1.6 for forced induction applications to make sure it all gets out of there.
10:36 PM
