Window motor - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-17-2012, 12:20 PM   #1
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
Window motor
Well my passenger side window decided not to roll up so I thought I can make a thread on the repair.. Pics coming soon
Also of anyone knows any tips or tricks chime in..
The first thing I'm checking is the window switches. I know that they are a complete circuit so if one isnt making continuity neither will work.
90GTNovi2000 is offline
Old 05-17-2012, 01:16 PM   #2
Forum Car Trader
Ok damn we'll both switches are good.. I put juice straight to the motor it just hum's it won't move.. Sounds like my window motor went bad..
ID:	50783   Click image for larger version
Old 05-17-2012, 01:21 PM   #3
Forum Car Trader
Very simple!! Next step
Old 05-17-2012, 01:49 PM   #4
Forum Car Trader
Well I am doing something wrong my motor is fine. I'm gonna re check the switch
---------- Post added at 02:49 PM ---------- Previous post was at 02:29 PM ----------
I'm really not to sure what it could be!! I tore it apart and just put it back together and now it works great!! I think the motor may have been in a bind or its on it's way out.. Anyways hell yeah I love easy fixes
Old 05-17-2012, 03:33 PM   #5
Senior Member
dreamstang is unknown around these parts
Nice. My suggestion was to be to check voltage at the switches and motor and see where the power was lost at. Got to love it when that happens.
One time I was outta town for 8 months for work. I bought a beater work car. Maybe grand am I think. And the lifters were clattering. So like a rookie I ripped the topend off in a parking lot. Then to find out I couldn't get the lifters for like 1-2 months! So put it back together retorquing the bolts. And the clatter was gone. I was a pretty happy guy!
dreamstang is offline
Old 05-17-2012, 04:40 PM   #6
Senior Member
Trojan Horse is just getting started.
Re: Window motor
1. Make sure the gear drive and roller pins are in good shape.
2. It may be that you have a dead spot in the window motor's armature, in which case if/when it stops on that spot again, it will not work until the motor is rotated past that spot.
Trojan Horse is offline
Old 05-17-2012, 09:39 PM   #7
Jkgravy's Avatar
Jkgravy is unknown around these parts
Tearing it down you should have seen three little plastic balls in there, around the white gear that is in there. I have fixed a bunch of them and that has always been the problem. I guess they just get old and just crumble.
Jkgravy is offline
Old 05-29-2012, 07:49 PM   #8
Forum Car Trader
Ok so now my driver side window won't go down.. WTF!!
Old 05-29-2012, 07:58 PM   #9
Senior Member
That sux man.
Old 05-30-2012, 05:44 PM   #10
Filibuster
XXSTEVEO66 is unknown around these parts
This is why I wired my own Window switches...I hate chasing wires id rather just rip them out and run my own:/...I hope you get the problem solved soon good luck!..
XXSTEVEO66 is offline
Old 05-30-2012, 05:49 PM   #11
Forum Car Trader
Yes the motor went bad.. I pulled it and put juice to it and nothing I tapped with a hammer then it spun a lil and locked up for good... It's time for a new one! it's still the stock motor and had actually never been serviced.. Everything looked untouched!
Old 05-30-2012, 06:09 PM   #12
Filibuster
Good...well if I can say a good thing ive noticed of mustang vs chevy is that the Window motors (though the switches are prone to falure) last in my stang!...I changed motors 3x on my 82 camaro (2x driver side 1x pass) and my 97 has had both driver and pass changed and the driver side is goin out again!..and changing them on the 97 is a PAIN!...
I just love the simplicity of the fox!.
Old 05-30-2012, 07:07 PM   #13
Senior Member
time to go manual! lol dam window motors
Old 05-30-2012, 08:55 PM   #14
Senior Member
Re: Window motor
Check the gearbox. All you may need is the gearbox rebuild kit or plastic roller pins.
It is a lot cheaper than the entire assembly.
Old 05-30-2012, 09:12 PM   #15
Forum Car Trader
How do I check the gear box? Is there a write up on rebuilding one cause I'd much rather rebuild it and learn something new and if I break it the loss won't be bad..
Old 05-30-2012, 09:24 PM   #16
Senior Member
Re: Window motor
Just take the cover off and look inside. It is pretty easy to do.
Here's a repair article - Window Motor Gearbox Repair
Old 05-30-2012, 09:29 PM   #17
Forum Car Trader
Hell that's simple i cant wait..
Old 05-30-2012, 09:35 PM   #18
Forum Car Trader
Wow it completely ate it up!!!
Old 05-30-2012, 09:37 PM   #19
Forum Car Trader
Lol
Old 05-30-2012, 11:04 PM   #20
Senior Member
Re: Window motor
Lol
Nom, nom, nom.....
Make sure the motor runs ok when you get it cleaned out.
Old 06-04-2012, 06:49 PM   #21
Forum Car Trader
Where can I find a new one of these? And about how much is it.. It's obviously the power relay for the motor but it's roasted...
ID:	53261   Click image for larger version
Old 06-04-2012, 07:27 PM   #22
Senior Member
try rock auto. i bet they would have one. if not mps auto salvage or ehp the site sponsor for used
Old 06-04-2012, 10:00 PM   #23
Senior Member
Re: Window motor
That's the motor.
It's dead.
$75 at LRS
Your local auto parts may have them cheaper.
Old 06-05-2012, 06:54 AM   #24
Forum Car Trader
I will prob just grab a cheap one off Craigslist and run it until it breaks... But on the bright side I understand the window motor now.. And now have a few spare parts..
Old 06-05-2012, 04:51 PM   #25
Mweigt07's Avatar
Mweigt07 is unknown around these parts
I ended up just cleaning my motor( the internals) and just sprayed some eletrical spray on it. Works like a champ and still works after 6 years of doing that. I replaced the window swicth I couldn't fix that lol. Its not a hard job if it works for you
Mweigt07 is offline
Old 06-05-2012, 04:55 PM   #26
Forum Car Trader
It's not hard at all but I went more in depth than just spraying it with a lubricant.. I tore it down to find the cause and it is trash..
Old 06-05-2012, 04:58 PM   #27
Mweigt07's Avatar
Yeah my comunator( I don't know how to spell it) was full of grease so the brushes didn't have good contact, I guess I got lucky lol
Mweigt07 is offline
Closed Thread
10:40 PM
