So my rear sway bar is lose... - Mustang Evolution
Old 05-17-2012, 05:57 PM   #1
1995boss's Avatar
I know my rear shocks need to be replaced and I was driving around and heard a knocking noise in the rear and just see its the rear sway bar.
What do I need to tighten it back up? Is it a bolt of so what's the dimensions or is it parts specific?
My cars a 1995 gt 5 speed.
1995boss is offline   Reply With Quote
Old 05-17-2012, 06:38 PM   #2
Re: So my rear sway bar is lose...
They are bolted on and I believe they may have had "captive" nuts.
Not sure what size, maybe metric though.
Maybe it is just loose and you can tighten it up?
Old 05-17-2012, 07:16 PM   #3
1995boss's Avatar
Lol it's hanging down my friend lol
Old 05-17-2012, 07:19 PM   #4
just look at the other side, or whatever is still on there and match it up.
Old 05-17-2012, 07:31 PM   #5
That's not good!
^^ What he said. ^^
Old 05-17-2012, 07:46 PM   #6
Titus Wadicus
svtlx's Avatar
wutever u tighten them up with...be sure u use hardened grade 8 or better bolts and nuts... just went through that b.s. i got uca/lca and stiff *** specific rate lowering springs with h.d. shocks. it was beating the hell outa my sway bar bolts
just my .02
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-17-2012, 07:50 PM   #7
1995boss's Avatar
Well fellas guess its broke went to take a look at it and it broke from the bolt hole.
Old 05-17-2012, 07:55 PM   #8
Forum Car Trader
90GTNovi2000's Avatar
Take pics!!
90GTNovi2000 is offline   Reply With Quote
Old 05-17-2012, 07:56 PM   #9
looks like a good time for an upgrade.
Old 05-17-2012, 11:40 PM   #10
1995boss's Avatar
Originally Posted by 90GTNovi2000 View Post
Take pics!!
Just for you!
---------- Post added at 12:40 AM ---------- Previous post was at 12:13 AM ----------
So i took pictures step by step. It's fairly easy to do.
Items needed-
Floor jack would be best, or lift if your lucky.
Socket wrench and extension
4 way, or a socket wrench
Maybe a hammer (i used one)
First trace to find the two bolts that are holding the rear sway bar.
The first bolt can be done with the wheel on and the other needs to have the wheel taken off. (Hint the first bolt will have a little cut out in the wheel well so you can put your extension on their)
Second take the wheel off
To get to this bolt behind the wheel
This is the same bracket as shown before (behind the tire) that needs to be taken off.
You'll have to move the cable out of the way so i used a hammer to TAP on the bracket holding it to help brake it lose.
Once taken off and the sway bar removed from that side reassemble. Putting the bracket back to this
With all that said this is what i was dealing with taking me A LOT more time than it really should of (with some brakes with a beer or 2)
Having a floor jack put in the middle of the rear end would make this a very simple task.
Now for the hell of it I shot some pics of the crap i had to use.
I don't know why, but i couldn't find a 4 way around my farm (crazy right?) and was way to lazy to get mine out from under my trunk mat.
And then i had to use this POS to lift my car because i didn't know the valve was broken on are floor jack.
Here's my reason for this task. I didn't replace i just got ride of it for now till I gather some cash to put into the car and do it all at once.
Then this is what it will look like when you pull the stock rear sway out.
Old 05-18-2012, 06:52 AM   #11
Forum Car Trader
Looks like scrap metal to me.. Time to upgrade what are you replacing it with?
Old 05-18-2012, 07:24 AM   #12
I've never seen a sway bar just break like that, from wrecks or hitting the on something sure, but that looks like it just broke off.
Any idea what might have done it?
Old 05-18-2012, 08:26 AM   #13
1995boss's Avatar
Well from doin so research and looking into it sounds like this is common among Sn95 models.
I was pulling out of a parking lot with a little incline and it just broke
---------- Post added at 09:26 AM ---------- Previous post was at 09:24 AM ----------
Not sure at the moment, but I hear the thicker the better
Old 05-18-2012, 08:38 AM   #14
Hmmm, Probably not tempered properly and instead of flexing it was bending till it broke.
If you want to autocross or road race a thicker HD bar would be better.
Drag racing you'd be better off just using the stock bar for the street and use a quick disconnect anti-roll bar for the strip. See dreamstang's "What it takes" thread for links to bars and installations. We were just talking about this yesterday.
01:53 PM
