Coolant System Questions - Mustang Evolution
Old 05-17-2012, 06:18 PM   #1
I have currently done a full rebuild and clean up to my engine along with many performance upgrades while coming to the last bits and pieces to do while on the stand i was curious how to run my coolant hoses from my heater core now that I no longer have a crossover tube I was wondering if any body could show me pictures on how they have done theirs with all sencors as im staying with the fuel injection
Thank You to those who respond
96 F150 Eddie Bauer
10 Focus
87 Mustang GT
08 Aprilia SXV 550
mcdonaldnick is offline   Reply With Quote
Old 05-17-2012, 06:36 PM   #2
Re: Coolant System Questions
The tubes are probably the "cleanest" way to feed and return coolant to the heater core, but you could probably do it with hose and fittings too.
Old 05-18-2012, 07:14 AM   #3
I have an after market Edelbrock Performer Intake that has a taller lower plenium that will not allow rotation of crossover tube for instalution
96 F150 Eddie Bauer
10 Focus
87 Mustang GT
08 Aprilia SXV 550
Old 05-18-2012, 08:05 AM   #4
Then, bend you up some new ones out of the appropriate sized copper tubing.
It won't rust and you can add fittings as needed for any sensors or gauges.
Old 05-18-2012, 09:35 AM   #5
That is fantastic that never even entered my mind thank you
96 F150 Eddie Bauer
10 Focus
87 Mustang GT
08 Aprilia SXV 550
Old 05-18-2012, 10:31 AM   #6
You're welcome.
It comes from years of working as a plumber, electrician, mechanic, fabricator, pipe fitter, etc., etc..............and the necessity from being broke or needing something that just isn't available.
P.S. Type L or type K copper will work the best and lacking access to a bender you can fill the tube (pack it in good) with sand or other fine grained media, tape off the ends securely and carefully bend them to your desired configuration. Just be sure to clean & blow them out really good before using.
08:54 AM
