New to the 5.0 - Mustang Evolution
Old 05-18-2012, 03:23 PM   #1
Maddhatter88's Avatar
New to the 5.0
I've got a 5.0 1990 lx im wanting to do a Kenni Bell BlowZilla build and I've tea mixed reviewes on the trick flow intakes and the typhoon intakes. What intake would b best for my build? I'm most likely doing a SVO block if that helps any
Maddhatter88 is offline   Reply With Quote
Old 05-18-2012, 03:29 PM   #2
Stang.racr's Avatar
Both intakes are pretty good but if you got that supercharger you wouldn't be using the intakes.
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-18-2012, 03:35 PM   #3
Oh does it come with its own intake?
Old 05-18-2012, 03:52 PM   #4
Forum Car Trader
90GTNovi2000's Avatar
The kenne belle mounts on top of the Lower intake
90GTNovi2000 is offline   Reply With Quote
Old 05-18-2012, 04:16 PM   #5
Yea I know that, hints why im asking about what's the best intake to use with it. I know the blower takes the place of the upper intake lol
Old 05-18-2012, 04:25 PM   #6
Re: New to the 5.0
The Kenne Bell requires either the stock 5.0 lower or the GT40/Cobra lower intake.
Your best bet is to get the GT40/Cobra lower and have it ported by TMoss Porting.
I would get the Blowzilla blower and the Flowzilla air intake for it.
Originally Posted by Kenne Bell
TB1000-FB KIT $3699.00 BLOWZILLA/FLOWZILLA 8-18 PSI KIT W/AC-GT40 LOWER ('86-'93 MUSTANG 5.0)
Old 05-18-2012, 05:17 PM   #7
Yea it already has a gt40 intake off a cobra on it Thanks so they r good for massive power? Well like the 6-800HP range
Old 05-18-2012, 05:28 PM   #8
WhiteCobra94's Avatar
Yea with a good set of heads and cam
---------- Post added at 05:28 PM ---------- Previous post was at 05:27 PM ----------
Aluminum block with forged internals
Old 05-18-2012, 05:38 PM   #9
Re: New to the 5.0
With the intake ported out, a good set of heads and the KB with the boost turned up yes, but your stock 5.0 block won't hold that much power for very long.
You'll need to go with a Boss 302 or Boss 351W block and all forged internals to handle that much power.
Old 05-18-2012, 05:45 PM   #10
Yea I was thinking bout a SVO or DART block. Bc the stock block hold like what 500hp? Sry if this posted twice damn iPhones
Old 05-18-2012, 05:49 PM   #11
maybe 500 with a perfect tune. but that is pushing it.
Old 05-18-2012, 05:57 PM   #12
Yea. What kinda heads do y'all suggest?
Old 05-18-2012, 06:06 PM   #13
Re: New to the 5.0
Edelbrock, AFR, Trick Flow, any good name brand will suffice.
Old 05-18-2012, 06:09 PM   #14
Sweet. Thanks man. What's the best compression for FI
Old 05-18-2012, 06:17 PM   #15
Re: New to the 5.0
8 to 8.5:1 is probably best if you are going for high boost.
Old 05-18-2012, 07:36 PM   #16
Ok. Thanks man.
04:59 PM
