Problem!!!!! - Mustang Evolution
Old 05-19-2012, 06:52 AM   #1
Jeff44's Avatar
Problem!!!!!
When I turn my car off something is still continuously running that it drains my car battery. I can't figure out what it might be but it never turns off. I have to disconnect the battery for it to turn off. Does anybody know what this might be? Any help would be appreciated. Thanks
Jeff44 is offline   Reply With Quote
Old 05-19-2012, 07:02 AM   #2
jwhayne0001's Avatar
Glovebox light, radio, security systems etc...
jwhayne0001 is offline   Reply With Quote
Old 05-19-2012, 07:15 AM   #3
Jeff44's Avatar
If I go to the rear of the car it sounds like it is the noise is by the gas tank
Old 05-19-2012, 07:17 AM   #4
Is this a new car?
Because it sounds like the fuel pump may have a kill switch that you are unaware of.
Old 05-19-2012, 07:18 AM   #5
Jeff44's Avatar
No it's a 1987 convertible
Old 05-19-2012, 07:19 AM   #6
What I meant did u just get it?
Old 05-19-2012, 07:21 AM   #7
Jeff44's Avatar
Lol yes sorry
Old 05-19-2012, 07:27 AM   #8
Trace the fuel pump wiring. There maybe a switch to turn it off.
If you open the fuel door and listen is it louder?
Are you carburated? If so you may have an external pump. In that case the pump would be mounted somewhere by the tank outside of it, probably by the fuel filter.
A common place for the switch would be by the drivers seat. Because that's where the original fuel pump relay was.
Old 05-19-2012, 07:38 AM   #9
Re: Problem!!!!!
Fuel pump relay may be stuck on.
Old 05-19-2012, 08:26 AM   #10
Jeff44's Avatar
It's fuel injected. When I put the battery Leeds on I feel the fuel lines and I can feel the fuel moving. I don't know much about this and I am getting frustrated
---------- Post added at 10:26 AM ---------- Previous post was at 10:26 AM ----------
How do you free up the relay
Old 05-19-2012, 08:49 AM   #11
You have to replace it if that's the problem.
It's under the drivers seat.
Old 05-19-2012, 09:23 AM   #12
Jeff44's Avatar
Wow ok I will check it out thanks.
Old 05-19-2012, 09:29 AM   #13
It's real easy. There are a couple wire harnesses and on bolt holding it in. If you have a Haynes or Chilton manual with a wiring diagram you can test it. If not you can Google one. I don't remember the proper way ,But you can test for voltage on the out end of the relay. it probably shouldn't have voltage when the key is off. But you will need to look at a diagram to find out what wire has voltage and what doesn't.
If this is over your head then just replace it. But really its pretty easy to test and or replace.
Old 05-19-2012, 09:54 AM   #14
Jeff44's Avatar
You are the man! I unplugged the relay and plugged it back in and the noise went away. A simple task and you knew what it was. Thank you for all your help
---------- Post added at 11:54 AM ---------- Previous post was at 11:52 AM ----------
Thank you too Trojan Horse
Old 05-19-2012, 09:58 AM   #15
It was Trojans suggestion. He is the man. I just simply helped trouble shoot. Thanx though.
Old 05-19-2012, 10:52 AM   #16
Re: Problem!!!!!
You're welcome Jeff, glad you found the problem.
dreamstang this one is yours, your mention of the relay first, triggered the connection in my brain for my answer.
Old 05-19-2012, 10:53 AM   #17
Fine! We will call it a team effort then.
Old 05-19-2012, 04:15 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
I had the same problem and cheated and put a toggle switch for the fuel pump.
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
01:13 AM
