91 5.0 Knocking sound - Page 5 - Mustang Evolution
Old 07-08-2012, 08:35 PM   #141
Originally Posted by JayKranz
I'm sticking with my 8.5lbs, so I should be okay.
I'm not trying to scare you or anything. Trojan know way more than me. What I would do is whatever info you find about everything keep that info. Then maybe your tuner can bump it up safely. I would get whatever boost you can, and request a SAFE tune.
Old 07-08-2012, 09:10 PM   #142
Quit scaring me I would bet the forged internals can handle it. Also, I am using my stock heads and intake for now so that will limit my power anyways.
JayKranz is offline   Reply With Quote
Old 07-08-2012, 09:19 PM   #143
with the added cubes you still may see aome increase in numbers. but not enough to worry about.
Old 07-08-2012, 09:20 PM   #144
Cool
Old 07-08-2012, 10:01 PM   #145
Re: 91 5.0 Knocking sound
Originally Posted by dreamstang View Post
Not to disagree, especially cause I'm no expert. But I still think its better to have lower compression ratio. I know u know this. But just want to make sure he is still careful after what happened last time
But with that said I also think it will be fine. All this said with respect as a boost virgin. Lol
You know you can always feel free to disagree whenever you think you should or need to.
I'm not one of those people who will blow up and get all stupid if someone disagrees with me.
It is definitely "better" to apply boost to a lower compression engine.
It lessens the chance of detonation and you can apply more boost without the detrimental effects you would have with higher compression.
Old 07-08-2012, 10:19 PM   #146
i know im in titled to my own opinion. but im not the most experienced with this situation. so just need for jay to know that your opinion is probably more accurate. i wantednto make sure jay is careful, even though i know he will be.
Old 07-08-2012, 10:52 PM   #147
I see.
The engine "killer" in most boosted applications is detonation.
He will have to be very careful with his boost levels and tune to prevent that.
Old 07-09-2012, 08:31 AM   #148
Forum Car Trader
90GTNovi2000's Avatar
What kind of numbers are you hoping for Jay??
90GTNovi2000 is offline   Reply With Quote
Old 07-09-2012, 08:33 AM   #149
I'd like to be around 400hp. I think that's doable.
Old 07-09-2012, 08:42 AM   #150
Forum Car Trader
The pics look good.. I love the pic of the motor in the lil car..
Which heads? Are they worked..
Old 07-09-2012, 08:57 AM   #151
They are stock E7 heads. I'm just using the stock top end, plus the Lunati cam that came with the engine. Next Summer I'll probably buy better heads etc... I know I'll catch some crap about the stock heads, but I have had bad budget breaking luck and just can't swing decent heads this year.
Old 07-09-2012, 09:01 AM   #152
Forum Car Trader
You will be fine on low boost.. But next summer when you get a set of great flowing heads and upper and lower all matched also... Then your talking power. Prob 480ish rwhp.
Old 07-09-2012, 09:04 AM   #153
Nice
Old 07-09-2012, 09:11 AM   #154
Forum Car Trader
Yeah no *****.. That would beat me!! And prob be a 10sec car with right supporting mods.
Old 07-09-2012, 09:20 AM   #155
Excellent, that's what I'm hoping.
---------- Post added at 10:20 AM ---------- Previous post was at 10:12 AM ----------
Would my 8.5lbs be considered low boost
Old 07-09-2012, 09:24 AM   #156
Forum Car Trader
No that's moderate.. Low would be IMO 4-6,. But start with the 6psi spring I would guess and a tuner will let you know if you can go to 8,.
Old 07-09-2012, 08:03 PM   #157
Is it easier to put my engine back in the car with the trans and accessories attached?
Old 07-09-2012, 09:51 PM   #158
If you have enough room to get it in there it is, but you will likely have clearance problems trying to get it tilted enough and far enough back to lower the front of the assembly.
Old 07-09-2012, 09:56 PM   #159
What about the bell housing? Is that normally installed as part of the trans or on the back of the engine?
---------- Post added at 10:56 PM ---------- Previous post was at 10:52 PM ----------
Just not sure what the easiest reinstallation order would be.
Old 07-09-2012, 10:11 PM   #160
Lorraine's driver
ab_mach1's Avatar
Car looks great! Love that shade of red
Instagram: @ab_mach1
Old 07-09-2012, 10:20 PM   #161
You might be able to get the engine with the bellhousing on it to slide in there fairly easy.
TBH, I never tried it on a Fox Body with anything more than the flywheel on the back of the engine.
Measure the engine and bellhousing, then measure the engine bay. If there is enough room for it to drop straight in or it is really close, then likely it will fit ok.
Old 07-10-2012, 05:55 AM   #162
Forum Car Trader
Yes motor and trans together the stab both take your time and watch your trans.. With the right angle and 2 guys it's possible. Once the trans and motor are in at a angle get someone under the car near the trans tunnel to guide it in slowly.. This will save you alot of time.
Old 07-10-2012, 06:21 AM   #163
It would probably be not to bad if you had an engine hoist leveler.
Old 07-10-2012, 07:22 AM   #164
Forum Car Trader
We used a couple sand bags cause it will try to nose dive..
Old 07-10-2012, 07:45 AM   #165
Since I have painted everything and it looks nice I think I will do it the careful way and sacrifice my boulder blades on the concrete garage floor. First engine then trans
Old 07-10-2012, 07:52 AM   #166
Forum Car Trader
You can wrap a towel around the trans to save the paint. It will save you an hour.. But if you have a trans jack get after it..
Old 07-10-2012, 07:54 AM   #167
My step brother is my Trans Jack
Old 07-10-2012, 07:58 AM   #168
It's not me, it's you.
primer2tone's Avatar
Ouch! I've been that guy before. Lol
Old 07-10-2012, 09:38 AM   #169
Forum Car Trader
Lol.. Don't kill him they fall fast I've broken cases and barely dodged some accidents. JS! be careful work smarter not harder!!
Old 07-10-2012, 09:46 AM   #170
I pulled it out by hand.
Old 07-10-2012, 10:29 AM   #171
That statement is SO open to misinterpretation.
Old 07-10-2012, 10:32 AM   #172
Haha, after reading it again it sure is. I pulled the trans out by hand, better?
Old 07-10-2012, 10:37 AM   #173
There you go, now no "improper" images pop into my head.
Old 07-10-2012, 11:21 AM   #174
Idk. I still get improper images with just saying trans/trannies etc. Maybe its just me. Lol.
Old 07-10-2012, 11:23 AM   #175
Forum Car Trader
Lol so it doesn't help to say I always put a beating on my trans!!
04:23 AM
