91 5.0 Knocking sound - Page 6 - Mustang Evolution
Old 07-10-2012, 11:26 AM   #176
Originally Posted by 90GTNovi2000
Lol so it doesn't help to say I always put a beating on my trans!!
Lol. Makes us wonder what you do in your free time.
---------- Post added at 12:26 PM ---------- Previous post was at 12:24 PM ----------
Oh yeah. Sorry jay if I helped stray off topic. I see bait and I take it.
Old 07-10-2012, 03:16 PM   #177
Haha, no I'm good. Not a topic Nazi
JayKranz is offline   Reply With Quote
Old 07-10-2012, 03:19 PM   #178
sweet. now back to the shenanigans. haha
Old 07-10-2012, 07:35 PM   #179
Proper break in process for this new motor?
Old 07-10-2012, 07:38 PM   #180
I leave this one for someone more experienced.
Old 07-11-2012, 03:06 AM   #181
Re: 91 5.0 Knocking sound
You will find numerous opinions on that subject.
For mine, I drive them easy up and down through the rpm range for the first 500 miles and let them go through several heating and cooling cycles.
Then I change the oil and observe how much metal is in the oil and on the magnetic oil pan plugs I always use. If it does not appear excessive (It usually won't) I complete the oil change and drive it like I intend to after that. I will change the oil again and make the same observations at 1000 and 3000 miles, then just change it at regular 3-5000 mile intervals depending on how dirty the oil appears when I check it. I don't stick to any certain mileage for my oil changes because if I do a lot of short trips the oil will get dirty and contaminated faster than if I do long trips. So I go by how dirty the oil looks when I check the level. If it is coal, tar black, it gets changed.
Old 07-11-2012, 05:24 AM   #182
okay thanks
Old 07-11-2012, 12:11 PM   #183
You're Welcome & Good Luck with your project.
Old 07-12-2012, 07:21 PM   #184
I have the distributor at tdc I think.
---------- Post added at 08:21 PM ---------- Previous post was at 08:21 PM ----------
What's next? I'm not understanding this timing.
Old 07-13-2012, 12:51 AM   #185
you want the crank at 0* tdc on the compression stroke. you can tell if is compression stroke by holding your finger over the #1 spark plug hole. once your set, stab the distributor. you want the rotor pointing at the #1 spot on the cap, which is usually straight back. once u get it stabbed and pointing at 1 then just put the wires on, in firing order counter clockwose.
note. when i set tdc at crank. i dont set it to 0*. i set it at my base timing 10-14*
Old 07-13-2012, 05:13 AM   #186
Okay, thanks
06:29 AM
