Gears - Page 2 - Mustang Evolution
Old 06-02-2012, 11:11 AM   #36
Maddhatter88's Avatar
U and me both lol dpi it little by little it's not my DD so it's easier to work on it
---------- Post added at 12:11 PM ---------- Previous post was at 12:10 PM ----------
Ment do it little by little
Maddhatter88 is offline   Reply With Quote
Old 06-02-2012, 11:13 AM   #37
Little steps are all u need
Mady is offline   Reply With Quote
Old 06-02-2012, 11:15 AM   #38
Yep get in a big rush u mess stuff up or do stuff u really dnt want to do U cut corners
Old 06-02-2012, 01:28 PM   #39
Originally Posted by dreamstang
just jack the rear up. turn the tire exactly one revolution and count the exact amount of drive shaft rotation.
3 1/4 = 3.27
3 3/4 = 3.73
So if it turned 3 1/2 that means they r 3 :55 right?
Old 06-02-2012, 01:29 PM   #40
Yes
Old 06-02-2012, 01:38 PM   #41
Ok now I finally know exactly what I have. Thanks.
Old 06-02-2012, 01:43 PM   #42
ColeJohnson's Avatar
Originally Posted by Mady
I want to get 4.10 gears
We're gonna be great friends! I absolutely love my 4.10s on my '02 GT and my mpg average only went down roughly 2-3mpg.
You should check out the threads in my signature.
2016 Comp Orange GT (current)
Old 06-02-2012, 01:45 PM   #43
Re: Gears
Here Mady, Check out this post. Don't Fear The Gear You'll be happy with the 4.10's and they don't affect your MPG as bad as some might think.
Old 06-02-2012, 02:13 PM   #44
Well of his runs 80mph at like 2500 then why does mine run 3000 at 75mph?
Old 06-02-2012, 02:14 PM   #45
I bet you have a 4 cylinder trans.
Old 06-02-2012, 02:16 PM   #46
Dude said its the stock trans. Lol everything else he has said about the car has been right so far but who knows
---------- Post added at 03:16 PM ---------- Previous post was at 03:16 PM ----------
Wait will a 4banger trans even bolt up to a 5.0?
Old 06-02-2012, 02:18 PM   #47
It will bolt up with a ranger pilot bearing. The only thing different is the input shaft diameter.
You could pull the numbers off the metal is tag hanging near the rear of the trans.
The only other thing that could explain it is you have small tire height.
Old 06-02-2012, 02:22 PM   #48
I'll look at that when I go back to the garage Monday. And yea it's got 16's on it with I think with 50 or 60 series can't remember off hand
Old 06-02-2012, 02:23 PM   #49
Re: Gears
Depends on which transmission you have and the OD gear ratio.
If you are running 3k at 75, do you even have an OD transmission?
Old 06-02-2012, 03:01 PM   #50
It's a 5 speed manual trans
Old 06-02-2012, 03:06 PM   #51
Storm13_5.0's Avatar
I turn 1600 @ 55 what ratio do I have ?
Storm13_5.0 is offline   Reply With Quote
Old 06-02-2012, 03:10 PM   #52
Re: Gears
Get me the trans tag number, your rear end gear ratio & tire size.
Pull the rear end cover (You need to change the oil and additive anyways right?) and count the teeth on both the ring and pinion gears if you are not 100% sure of the gear ratio.
Then I can figure out what is going on.
Old 06-02-2012, 03:12 PM   #53
Re: Gears
Depends on what your OD gear ratio and rear tire size are.
Probably anywhere from 3.08 - 3.55
Old 06-02-2012, 10:19 PM   #54
How you find the OD ? And I have 245 45 R17's in the rear
Old 06-02-2012, 11:57 PM   #55
Re: Gears
If you have a 5-speed, get the numbers off of the tag on the transmission.
Old 06-04-2012, 10:00 AM   #56
Ok. 3:55 gears, borg Warner R3 13-52-066-919 trans with p215/55/r16
---------- Post added at 10:58 AM ---------- Previous post was at 10:17 AM ----------
Looked it up and all I can find is it's from a 84 v8 but can't find the ratios
---------- Post added at 11:00 AM ---------- Previous post was at 10:58 AM ----------
Tag numbers. L97R 7003 AA REP A11
13-52-194 25249H2293
Old 06-04-2012, 10:02 AM   #57
WhiteCobra94's Avatar
I have 4.10s with a 3000 rpm stall, love it!!!
Old 06-04-2012, 09:45 PM   #58
Re: Gears
13-52-066-919 - These numbers come back as a casting number and are pretty much useless in trying to ID the transmission.
1352-194 - Ford 1989 Mustang 2.3L EFI WC, X 3.70-3.97 -2.34-1.48-1.00-0.79
As you can see that is a 4 cylinder transmission with an extremely low first gear of 3.97 and instead of the .68 OD ratio it has a .79 OD ratio, Which explains why it is revving at 3k at 75 MPH with the 3.55 gears.
Old 06-04-2012, 10:26 PM   #59
Dude u are freaking amazing!!! I've been looking at all kinds of stuff almost al day and couldn't find nothing and obviously what I did find was wrong lol
---------- Post added at 11:26 PM ---------- Previous post was at 11:18 PM ----------
So they dnt really hold up to much HP and TQ?
Old 06-04-2012, 10:37 PM   #60
Re: Gears
No, that transmission won't hold up to much HP/TQ or abuse.
P.S. When searching through Google or other search engines always try various wordings for your searches. The information is almost always there, you just have to try and figure out what someone else might have called what you are searching for. Frequently fewer words will produce better results.
Old 06-04-2012, 10:49 PM   #61
True and ok that's cool. Well if I get a trans built then I'll use those ratios. I actually like the feel of it. Just not for highway use
Old 06-05-2012, 04:22 AM   #62
Oh yeah. I called that one. Haha. If I were you I would drive it to it breaks. A lot of people get some good time out of them before they go.
Old 06-05-2012, 07:20 AM   #63
Is there a gear ratio calculater that could give me the final drive ratio? The ones I've found just give u the rear end gear ratio
Old 06-05-2012, 09:28 AM   #64
You could probably just do the math. The final drive ratio will change in every gear. But the engine would be the base as 1
1 x tranny gearing = a
A x rear gear ratio = final ratio
I think this is the formula.
Old 06-05-2012, 09:50 AM   #65
Sweet thanks
Old 06-05-2012, 10:39 AM   #66
Re: Gears
dreamstang is correct.
.79 x 3.55 = 2.8045 Final Drive Ratio
Note: This is not 100% exact and does not include any effects of different tire diameters.
Old 06-05-2012, 10:52 AM   #67
Oh ok that's cool. Yea gearing stuff is new to me. So 2.8FDG is low? Like I'm used to like 4x4 and gears bein like 4:88,5:27 etc that kinda stuff nvr dipped Ito the ratios between trans and rear end. Thanks guys. A lot
Old 06-05-2012, 11:33 AM   #68
Re: Gears
That's not extremely low, but compared to a V8 T5 fifth gear there is a good bit of difference.
.68 x 3.55 = 2.414
In a 4WD you have 3 multipliers to go through, the rear end, transmission and the transfer box. So it gets even more complicated and the final drive ends up being lower most cases.
Old 06-05-2012, 01:36 PM   #69
.68 x 3.55 = 2.414
Gotcha. If I did the math right I'm running the same ratio as a stock trans with 4:10 rear gears
Old 06-05-2012, 10:28 PM   #70
MikesChargedGT's Avatar
Then you would have you pretty much a track car. You for sure couldn't get on the highway lol
Alot of people run 4.10s hell I just ordered mine, it doesn't affect highway that much, you gain a couple hundred RPM it ain't gonna kill ya. 4.10s doesn't mean you can't hit the highway my truck runs 4.56s and I take it to the lake lol
---------- Post added at 04:28 AM ---------- Previous post was at 04:23 AM ----------
I was so late to that reply, my bad lol
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
12:36 PM
