rockers for track heat heads? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-21-2012, 11:42 AM   #1
SmokedLX's Avatar
SmokedLX is unknown around these parts
Hey so I got a super deal on some trick flow heads a while back from my friend but he kept his roller rockers, so i was wondering what I should get. I've got trickflow 185 heads with the track heat valve springs rated for 7k rpm. I also have 3/8 and 7/16 mounts. I was looking in the $160-$200 range. Any suggestions? I don't want any fragile Chinese eBay parts.
1991 Mustang LX - Rebuilt 302, cobra 80mm MAF, 75mm Trickflow Throttle Body, Ported GT40 Intake manifold, half inch plenum spacer, Ported trickflow twisted wedge heads w/ trackheat valvesprings, Scorpion 1.6 Roller Rockers, stock cam (for now), 24# injectors, trickflow pushrods, shorty headers, H-pipe with 4 magnaflow high performance cats, flowmaster 40s w/ axle dumps, 4.11 gears, aluminum driveshaft, Built AOD w/ 2800 stall, 16" Cobra R replicas, 245/50ZR16 street slicks...hopefully procharger next
SmokedLX is offline
Old 05-21-2012, 02:23 PM   #2
Senior Member
dreamstang is unknown around these parts
I have scorpion 1.72 on my trickflow 170s. They are really nice, but a little pricey.but they are lifetime warranty. If one ever fails they will send you a new one no questions asked. They also maybe a little overkill. They can handle 900 lbs of spring pressure.
dreamstang is offline
Old 05-21-2012, 02:27 PM   #3
SmokedLX's Avatar
I think my springs are max 800lbs. Im trying to stick with 1.6 rockers tho.
SmokedLX is offline
Old 05-21-2012, 02:45 PM   #4
Senior Member
They make the same rocker in 1.6
Just look how beefy they are.
Old 05-22-2012, 07:58 AM   #5
SmokedLX's Avatar
hmm...I'm gonna look into those
SmokedLX is offline
Old 05-22-2012, 06:05 PM   #6
SmokedLX's Avatar
I think I'll go with those scorpions. Should i get 3/8 or 7/16?
SmokedLX is offline
Old 05-22-2012, 06:11 PM   #7
Senior Member
you have to get whatever size studs you have. i think mine are 3/8 but i only have the 170 heads. so i dont know what size yours are. and you also have to make sure they are for the right pushrod. which mine are 5/16. so in my case i have 3/8 1.72 rr for 5 1/6 pushrod. if you dont kow for sure go to the trickflow website and look up your heads and it will tell you what sizes everything are.
Old 05-22-2012, 06:39 PM   #8
SmokedLX's Avatar
I have studs for 3/8 and 7/16, my pushrods are for 1.6 rockers.
SmokedLX is offline
Old 05-22-2012, 06:42 PM   #9
Senior Member
If you have both studs then I would use the 7/16 since they are probably stronger. I would contact summit racing or where ever you but and they will.help make sure you get the right ones for your setup.
Old 05-22-2012, 07:08 PM   #10
SmokedLX's Avatar
Cool thanks for the help!
SmokedLX is offline
Old 05-22-2012, 07:18 PM   #11
Senior Member
no problem
---------- Post added at 08:18 PM ---------- Previous post was at 08:14 PM ----------
hey man. if you get a chance stop by the mustang of the month and show some fox love. if you dont want to or have time no biggie. its just a real close race. i am only like 2 votes ahead and woukd be stoked to win.
Old 05-22-2012, 08:50 PM   #12
Senior Member
Trojan Horse is just getting started.
Re: rockers for track heat heads?
You will have to use whichever studs that will fit your heads.
They won't be tapped for both sizes and if you have pedestal mounts you will have to get rockers for them.
Trojan Horse is offline
Closed Thread
03:30 AM
