Erg lines... 94 gt - Mustang Evolution
Old 05-21-2012, 03:57 PM   #1
Erg lines... 94 gt
Removed my egr lines ,air pump and plugged off the back of the heads. Any major probs that can occur from this?
Jake walking to is offline   Reply With Quote
Old 05-21-2012, 05:36 PM   #2
87blackonblack's Avatar
As long as u pluged all the correct lines to the egr and there are no leaks vacuum wise you should be just fine.
87blackonblack is offline   Reply With Quote
Old 05-21-2012, 06:03 PM   #3
Do I need to vent anything? Valve covers are solid except for the oil filler neck.
Old 05-21-2012, 06:19 PM   #4
Do you have a pcv? If not it would be a good idea for some breathers.
Old 05-21-2012, 06:33 PM   #5
No Pcv. Do I need new valve covers or is there another way to allow it to "breath"?
Old 05-21-2012, 06:36 PM   #6
You could add a breather hole with a whole saw. Then put a baffle in it. If your stock oil filler is like mine it will have a hose barbs. You can put a rubber line with a pcv on that to the air intake.
P.s. I do have some valve covers for sale.
Old 05-21-2012, 08:38 PM   #7
Storm13_5.0's Avatar
What does the breather do?
Storm13_5.0 is offline   Reply With Quote
Old 05-21-2012, 08:40 PM   #8
Help keep crankcase pressure down and expells moisture.
Old 05-21-2012, 08:49 PM   #9
Hard install?
Old 05-21-2012, 09:01 PM   #10
Originally Posted by Storm13_5.0
Hard install?
no not at all.
Old 05-22-2012, 12:02 AM   #11
I'll have to look into this lol!
10:37 AM
