long tube headers torment question - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-22-2012, 09:14 AM   #1
fordracing63857 is unknown around these parts
After I get everything put back in the steering doesn't wanna turn like it should. It's hitting the header right where the steering bolts into the rack and punkin .91 GT, 5speed.....
fordracing63857 is offline
Old 05-22-2012, 10:08 AM   #2
Senior Member
dreamstang is unknown around these parts
You may have to manipulate the header a little bit. It's common. Just use a ball peen hammer and be careful.
dreamstang is offline
Old 05-22-2012, 11:15 AM   #3
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
I had to do that to my shorties. You may also be able to move the column a little bit to gain some clearance too.
93slowstang is offline
Old 05-22-2012, 07:46 PM   #4
How do I go about moving the column?!?!?
Old 05-22-2012, 09:26 PM   #5
Moderator
Loosen the four bolts that hold your column under the dash, then go under the hood and pull the shaft away from the headers. It will slightly move your steering wheel but not enough to really notice. If you still don't have enough clearance you will likely have to ding the header pipe.
Closed Thread
12:02 AM
