Bad? - Mustang Evolution
Old 05-23-2012, 08:12 AM   #1
Storm13_5.0's Avatar
Bad?
I found this un plugged off the back of my intake manifold ... What is it ? An will it cause anything bad
Storm13_5.0 is offline   Reply With Quote
Old 05-23-2012, 08:26 AM   #2
Quball19's Avatar
Yes pcv , needs plugged in back off block, passenger side kinda hard to get to . You can have oil coming out.
Quball19 is offline   Reply With Quote
Old 05-23-2012, 08:43 AM   #3
Geeze ... So what would cause it to pop out ?
And I got it back in
Old 05-23-2012, 08:46 AM   #4
Quball19's Avatar
Not sure, you might off grabbed the line by accident and pulled it out.
Old 05-23-2012, 08:47 AM   #5
Jus makin sure it wasn't a really bad sign or anything ... What's it do?
Old 05-23-2012, 08:49 AM   #6
Quball19's Avatar
Pressure control valve , controls pressure in crank case, vents pressure so don't build up and go boom
Old 05-23-2012, 08:52 AM   #7
Well that sounds like something ya don't war to stop workin
Old 05-23-2012, 08:59 AM   #8
Quball19's Avatar
No, would not be good.
Old 05-23-2012, 10:29 AM   #9
Re: Bad?
PCV = Positive Crankcase Ventilation valve
Everything else Quball said is correct.
Old 05-23-2012, 10:35 AM   #10
Quball19's Avatar
Oops sorry , thanks for correction
---------- Post added at 10:35 AM ---------- Previous post was at 10:30 AM ----------
Well, I tried lol..... Don't I get a "E" for effort ?
Old 05-23-2012, 11:14 AM   #11
Re: Bad?
Yes you do. You did very well and it's difficult to remember everything.
The only reason I can is from YEARS of having it pounded into my thick skull.
Old 05-23-2012, 11:46 AM   #12
Well glad I got it fixed ...
Its prolly bad that the line is cracked ...
Old 05-23-2012, 12:21 PM   #13
Re: Bad?
Attachment 51587
Yes, inspect and replace any cracked or damaged vacuum lines.
Old 05-23-2012, 12:47 PM   #14
Could it make my car run bad?
Old 05-23-2012, 12:58 PM   #15
Re: Bad?
Yes it can.
Old 05-23-2012, 01:00 PM   #16
Well it bogs down really hard
Old 05-23-2012, 01:05 PM   #17
Re: Bad?
That could be a fuel supply or pressure issue, or a timing issue.
A cracked leaking vacuum line at the fuel pressure regulator or in the system may cause fuel supply issues.
Inspect and replace vacuum lines as needed, then go from there if that doesn't cure the problem.
Old 05-23-2012, 01:08 PM   #18
Well I put that coil on you showed me .. And it fixed my idle and it runs up to about 3800 rpm now ... I suspect the EGR is leaking
06:38 AM
