Rear end - Mustang Evolution
Old 05-23-2012, 10:37 AM   #1
Jbeas50's Avatar
Rear end
My rear end is going out and I found two the first one is a 93 cobra rear end disc brakes and 3.08 gears the the second is a stock one with disc brakes and 3.55 gears there both 350 and ready just to bolt on and use which one should I get?
Jbeas50 is offline   Reply With Quote
Old 05-23-2012, 11:34 AM   #2
Jbeas50's Avatar
Does anyone have any advise on witch one I should get please????????
Old 05-23-2012, 12:30 PM   #3
Re: Rear end
Not much difference in the two, I'd get the one with the 3.55 gears myself.
Old 05-23-2012, 12:40 PM   #4
Jbeas50's Avatar
Ok that's what I was thinking of getting just making sure
---------- Post added at 01:40 PM ---------- Previous post was at 01:38 PM ----------
Thanks for the advise by the way
Old 05-23-2012, 12:57 PM   #5
Re: Rear end
You are welcome and good luck.
With the rear disk brakes you will need to change the proportioning valve and maybe the master cylinder too.
There should be an article in the Useful Info sticky thread.
Old 05-23-2012, 01:31 PM   #6
Jbeas50's Avatar
How much more will that cost cause I found an other rear end with the drums instead of the disk with 3.73 gears for 300 would I just be better off with that
Old 05-23-2012, 01:42 PM   #7
Re: Rear end
No, you wouldn't be "better off" the disk brakes will improve your stopping power which is always a good thing.
I do not know what a proportioning valve and master cylinder would cost, but I doubt it would be very expensive. Google search for some fitting a 93 Cobra, they should work for your purposes.
Old 05-23-2012, 02:22 PM   #8
Jbeas50's Avatar
Ok I will look into that
03:10 PM
