Fuel Pump question - Mustang Evolution
Old 05-23-2012, 07:23 PM   #1
Foxtrot's Avatar
Fuel Pump question
Ok so went to start the mustang for the first time in a year and it wouldn't start. I didn't hear the fuel pump kick on. Any reason why this would happen?
Foxtrot is offline   Reply With Quote
Old 05-23-2012, 07:35 PM   #2
Re: Fuel Pump question
Relay is bad.
Fuel Pump is bad.
Blown fuse.
Battery not fully charged.
Inertia switch activated or bad.
Old 05-23-2012, 09:19 PM   #3
Foxtrot's Avatar
Ok thanks I'll check all but the battery because I checked it with a volt meter and it was 11.96 volts thanks for the info.
Old 05-23-2012, 10:01 PM   #4
Battery should be at 12.5 volts or a bit higher fully charged.
Old 05-24-2012, 05:02 AM   #5
Yes less than 12 isn't real good with the car off. With it running it should be charging around 14.5
Old 05-28-2012, 09:21 PM   #6
Foxtrot's Avatar
Ok got the battery fully charged at 12.37 volts and replace the relay. I also check to make sure the inetra switch isn't set. Now TH mentioned something about a fuse? Does anyone know where this is possibly located? Just trying to trouble shoot anything before removing the gas tank and just testing the fuel pump. Again thanks for the replies
Old 05-28-2012, 09:55 PM   #7
Fuse box
Old 05-29-2012, 07:12 AM   #8
Forum Car Trader
90GTNovi2000's Avatar
Lol.. Yeah check your fuse box it's near your hood release.. Start there.. Then check the relay and so on
90GTNovi2000 is offline   Reply With Quote
Old 05-29-2012, 06:54 PM   #9
Foxtrot's Avatar
Ha yea I should have mentioned I checked some fuses but don't know which one is for the fuel pump. My bad haha.
Old 05-29-2012, 07:33 PM   #10
Sorry I don't remember what year your car is. But Google "(your year) mustang fuse box diagram" then select the images tab. You should find a fuse diagram no problem.
07:33 AM
