05-23-2012, 09:47 PM
#1 | | Registered User
| Burning oil..
Ever since I put my PVC valve back into place my car has been burnin a lot of oil
05-23-2012, 10:03 PM
#2 | | Senior Member
| Re: Burning oil.. Quote:
Originally Posted by Storm13_5.0 Ever since I put my PVC valve back into place my car has been burnin a lot of oil | Was the screen/filter in place under the PCV valve?
__________________ |
05-23-2012, 10:15 PM
#3 | | Registered User
I did not notice one ...
05-24-2012, 08:11 AM
#4 | | Senior Member
| Re: Burning oil..
Looks like this. LRS
05-24-2012, 01:44 PM
#5 | | Registered User
Yehp don't have that
05-24-2012, 02:19 PM
#6 | | Senior Member
Originally Posted by Storm13_5.0 Yehp don't have that | You need that to help keep the oil out of the intake.
The LRS above the picture is a link to the product.
05-24-2012, 04:27 PM
#7 | | Registered User
Thanks TH!!! |
05-24-2012, 05:56 PM
#8 | | Senior Member
05-24-2012, 07:49 PM
#9 | | Registered User
Thanks ! I just discoverd that it's leaking where it comes to the side of the manifold
05-25-2012, 11:18 AM
#10 | | Senior Member
Originally Posted by Storm13_5.0 Thanks ! I just discovered that it's leaking where it comes to the side of the manifold |
Not sure what you are talking about. Pic?
05-25-2012, 01:32 PM
#11 | | Registered User
It's leaking from that
05-25-2012, 02:11 PM
#12 | | Senior Member
05-25-2012, 09:02 PM
#13 | | Registered User
The intake . Sorry for being vague lol
05-25-2012, 10:06 PM
#14 | | Senior Member
Originally Posted by Storm13_5.0 The intake . Sorry for being vague lol | Ok, if it is dripping from that fitting, then you should remove it, clean it and reinstall it with some thread sealant.
The oil is probably coming from your PCV not having a screen/filter in it.
05-26-2012, 02:01 AM
#15 | | Registered User
Thanks I'll do that !!
So I noticed a lot about a clutch quadrant kit .. What does it do exactly ?
05-26-2012, 08:56 AM
#16 | | Senior Member
Originally Posted by Storm13_5.0 Thanks I'll do that !!
So I noticed a lot about a clutch quadrant kit .. What does it do exactly ? | It replaces the weak factory plastic quadrant.
05-27-2012, 02:54 PM
#17 | | Filibuster
Yeah I would definitely get an aftermarket quadrant..I replaced my clutch,and clutch cable without changing the stock quadrant and within a couple of days the stock plastic one was wearing out bad enough to cause 2-3 inches of play in the pedal..so instead of adjusting the cable I just swapped quadrants since then ive had no issues |
05-27-2012, 05:56 PM
#18 | | Registered User
So your clutch was going clear down to the floor basically ?
05-27-2012, 06:31 PM
#19 | | Filibuster
Almost half way to the floor..the aftermarket clutch is stiffer so it put more stress on the garbage stock quadrant..the stock ones are self adjusting,but instead of doing that I just replaced it after some helpful info I got from this forum..
05-27-2012, 06:42 PM
#20 | | Registered User
Interesting ill have to look into one , what you recommend ?
