Oil pan - Mustang Evolution
Old 05-24-2012, 03:12 PM   #1
Quball19's Avatar
Oil pan
I have a canton 7 qt oil pan, just put universal dip stick in, what do I use to plug stock dip stick?
Quball19 is offline   Reply With Quote
Old 05-24-2012, 03:25 PM   #2
the universal dipstick doesnt go into the same hole? sorry im not that familar with your pan
Old 05-24-2012, 03:35 PM   #3
Quball19's Avatar
No, it goes in side of pan. Pan had a set screw you take out,put in new stick
Old 05-24-2012, 03:41 PM   #4
so know you have an extra hole then..... imdont think they actually make plugs for those.
i think the best way would be to tap it, and add a plug. but the problem would be dropping shavings into the pan if its on the car.
i think your gonna have to find a tight fitting bolt and either epoxy or rtv it in there.
the only other thing that may work is modifying the factory dipstick into a plug. lke maybe sawing it down and sealing it.
---------- Post added at 04:41 PM ---------- Previous post was at 04:38 PM ----------
ohh wait. i may have lied. im not sure if these fit but.....
http://www.summitracing.com/search/?...k%20plug&dds=1
Old 05-24-2012, 03:48 PM   #5
Quball19's Avatar
Yes that just might do it. Thought about cutting old dip stick too, I believe i will order one of those,will look alot better. Thanks a million
Old 05-24-2012, 03:52 PM   #6
no problem. but i would maybe call them to check the size or fitment just to be sure. one is gm and one is for trannys. but as long as the size is the same it wont matter.
Old 05-24-2012, 03:54 PM   #7
Quball19's Avatar
When i looked at website it said for a 5.0 too. Looks like fits a few different engines, but will call to be safe
Old 05-24-2012, 03:55 PM   #8
ok cool. just would hate for you to buy something that didnt fit.
Old 05-24-2012, 03:57 PM   #9
Quball19's Avatar
Oopps no, my bad, that was for them bow ties
Old 05-24-2012, 04:01 PM   #10
i dont know for sure, but i would still think there is a chance it may fit. if not you will have to fab something up probably.
---------- Post added at 05:01 PM ---------- Previous post was at 04:58 PM ----------
if they dont fit you also maybe able to find something here?
Old 05-24-2012, 04:09 PM   #11
Quball19's Avatar
Yea,just called summit,they don't have them for Ford's. They said get diameter off old one go to local auto parts store see if they have freeze plug that small. Find out more tomorrow
Old 05-24-2012, 04:15 PM   #12
oh i forgot the link on my last post. http://www.mcmaster.com/#plugs/=hofp69
a freeze plug might work if they have them that small. but i wouldnt thread one in with the pan on even though that would be ideal.
Old 05-24-2012, 04:25 PM   #13
Quball19's Avatar
Seen a tapered one that expands but,it good at only 550 degrees,not sure if ill go that way. Have to look at that site see what else they have
Old 05-24-2012, 04:26 PM   #14
i would think 550* should be good enough.
Old 05-24-2012, 04:48 PM   #15
Quball19's Avatar
Yes agree, but would you try it on your car an chance it?
Old 05-24-2012, 04:50 PM   #16
if it says 550* i would. that is like header temps. the oil pan should never get that hot. what is it made out of?
---------- Post added at 05:50 PM ---------- Previous post was at 05:50 PM ----------
doesnt mean i wouldnt look around for the best solution first though.
Old 05-24-2012, 05:06 PM   #17
Quball19's Avatar
Says made of resilient rubber . Plug would go in block .yes am going to look around too,something out there just have to find it.
Old 05-24-2012, 05:14 PM   #18
Right on. Yeah I don't know that much about that material. But being a rubber sounds a little scary.
Old 05-24-2012, 05:18 PM   #19
Quball19's Avatar
Yea what i was thinking. Ill let you know what i come up with. Can't be that hard.......Lol
Old 05-24-2012, 05:55 PM   #20
Re: Oil pan
Is there a short metal tube sticking out of the block or just a hole in the block?
If you have a metal tube you can slide a compression fitting over it, then cap or plug the other end of the compression fitting as required.
Or, you can cut off the old dipstick tube and do that too.
Or you can cut off the old dipstick tube and pinch or weld the end shut.
Old 05-24-2012, 06:32 PM   #21
Quball19's Avatar
It is just a hole, I believe thats what I will do. The old dip stick fits a little loose ,so have to make it fit tighter .
---------- Post added at 06:32 PM ---------- Previous post was at 06:31 PM ----------
Thanks guys
Old 05-24-2012, 07:55 PM   #22
Re: Oil pan
Thanks guys
I have a "swaging" tool for that purpose.
Looks kind of like a punch but it is tapered and stepped up to different sizes.
You just carefully tap it into the inside of the tube to reshape or expand.
Old 05-25-2012, 02:29 PM   #23
Quball19's Avatar
Where can I get a tool like that? Or did you make it's.. Lol
---------- Post added at 02:29 PM ---------- Previous post was at 02:26 PM ----------
Didn't have time to mess with today. ... Indy 500 in town
Old 05-25-2012, 02:37 PM   #24
I'm sure you maybe able to get away with a tapered center punch.
Old 05-25-2012, 02:38 PM   #25
Re: Oil pan
Mine is home made. Turned it on a lathe at work years ago, but you can buy them.
Search for tubing swagers or expanders. You want the small hand driven type the hydraulic ones are prohibitively expensive.
Old 05-25-2012, 02:38 PM   #26
Quball19's Avatar
Cool, got one of those
Old 05-25-2012, 02:39 PM   #27
The real tool is way better I'm sure. But in a pinch I'm sure with the right taper you maybe able to taper it.
Old 05-25-2012, 02:40 PM   #28
Quball19's Avatar
Not swagger, tapered punch
Old 05-25-2012, 02:45 PM   #29
Re: Oil pan
The only advantage to a swaging tool over a tapered punch is that it will re-size the tube for a longer distance into the tube. To be honest you could grind or file down a piece of steel rod chucked in a drill and do the same thing. Just make it as smooth as possible and lubricate it.
Old 05-25-2012, 03:22 PM   #30
89BossGT's Avatar
The summit dipstick plug for Chevy will work on the Ford 302 block. I had the same problem finding a plug for my block when I installed a 7qt pan. Nobody makes a freeze plug that small. I tried the Chevy plug as a last resort and it fit perfectly.
89BossGT is offline   Reply With Quote
Old 05-25-2012, 03:23 PM   #31
I had a hunch it would. But I wasn't sure. That is good to know. That's why I suggested called them for the measurement.
08:11 AM
