Oil - Mustang Evolution
Old 05-25-2012, 02:01 PM   #1
89 coupe's Avatar
Oil
What's everybody's opinion on a good break in oil w/ weight and miles till change on a fresh rebuild.
89 coupe is offline   Reply With Quote
Old 05-25-2012, 02:12 PM   #2
Quball19's Avatar
I used 5 w 30 ...mobil super ..change after 500 miles then 2000.then you can run synthetic if you like
Quball19 is offline   Reply With Quote
Old 05-25-2012, 02:16 PM   #3
Re: Oil
+1 Any good petroleum based oil will serve for break in purposes and 5W30 is a good weight to use.
Old 05-25-2012, 03:44 PM   #4
WhiteCobra94's Avatar
Yes that's the oil I'm using , but have only driven 92 miles on new motor so far lol
Old 05-25-2012, 03:50 PM   #5
Quball19's Avatar
Keep going 408 miles to go. Get in an drive. Stagger your rpms.. Now one this part someone might have to correct me.....
---------- Post added at 03:50 PM ---------- Previous post was at 03:48 PM ----------
When driving let off gas let the torque slow you down, compression will help seat rings.... ( I believe thats right)?
Old 05-25-2012, 05:53 PM   #6
Re: Oil
Never heard that one before, but using the engine to brake the car puts a load on the rod caps, so I try not to do that much.
I just drive mine easy for a few miles, no set distance, and if everything seems ok then I go ahead and drive them like I intend to. Modern lubricants and metals are much better than they used to be and most rings are probably seated in within a 100 miles or so. I do change the oil out at 500-1000-2000 miles though, just to get rid of the wear in metals and debris.
Old 05-25-2012, 06:08 PM   #7
Quball19's Avatar
My dyno tune was telling me that. Not at high speed, just lifting off pedal letting in (rev down) so to speak. Just like to put out what I heard to do. I know ill be right or be corrected. Yea mon
04:27 AM
