Time for rebuild? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-26-2012, 07:30 AM   #1
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
Time for rebuild?
So yesterday I jumped in my car and ran to the store real quick. Well I didn't necessarily let it warm up enough and when taking off in low it felt like it was stalling out higher than normal.. So I put it in drive and it drove just fine. It took me about 2 mins since the store is around the corner on my way back I stopped and tried it again. This time it felt in a bind or something an hardly wanted to move. This was up an incline pulling it in my driveway.. I'm going to recheck the fluid today but it should be good considering it doesn't leak. Any suggestions?
90GTNovi2000 is offline
Old 05-26-2012, 07:41 AM   #2
Senior Member
dreamstang is unknown around these parts
What fluid are you talking about, the oil? Can you give us a little more details? Like stalling higher than normal.
P.s. with you s/c I would try not to drive it till the problem is solved. And if you are working on it , don't rev it either.
dreamstang is offline
Old 05-26-2012, 07:43 AM   #3
Forum Car Trader
I'm talking about the transmission 1st gear seems weird
Old 05-26-2012, 07:48 AM   #4
Senior Member
right. Lol.
If this happened suddenly, there is a good chance it could be the cable or quadrant. Even a bent fork. And clutch adjustment. Not for sure but worth checking first along with the fluid.
Old 05-26-2012, 08:20 AM   #5
Forum Car Trader
That would be nice.. Cause in drive it went in first and did just fine. It was like it was between gears and not quiet catching when I put in first manually.
Old 05-26-2012, 09:41 AM   #6
Senior Member
Trojan Horse is just getting started.
Re: Time for rebuild?
Sounds like the linkage may be out of adjustment and you actually had it between gears. When putting it in drive the trans detent probably insured the correct position. I would not be manually shifting the trans unless it has been built for it, especially with a supercharged engine.
P.S. this has nothing to do with your transmission, but drive slow and easy until your engine oil warms up good. Especially important if it is feeding your SC or Turbo too. Oil doesn't lubricate real well until it reaches about 180°.
Trojan Horse is offline
Old 05-26-2012, 12:23 PM   #7
Forum Car Trader
It's a built c4 but not a manual valve body, I do manually shift to much I've always had built auto's Just my preference. It's so nice when a lil evo or SS wants to run and you know your not gonna miss a gear..
Old 05-26-2012, 03:14 PM   #8
Senior Member
Hmmm, does it have a trans brake in it?
Just thinking that if it does and you accidently activated it, that may cause the symptoms you experienced.
Old 05-26-2012, 03:20 PM   #9
Senior Member
I totally brain darted this one. Haha
Old 05-26-2012, 03:32 PM   #10
Senior Member
It Happens!
Old 05-27-2012, 12:38 AM   #11
Forum Car Trader
No brake anywhere but idk of he removed it cause he told me he has been 6.9's in the eighth on the trans brake
---------- Post added at 01:38 AM ---------- Previous post was at 01:36 AM ----------
It also has stock ignition.. It doesn't have a 2 step so I doubt this trans has a brake.. Can they be removed?
Old 05-27-2012, 12:18 PM   #12
Senior Member
Yes, but you have to replace the entire valve body.
See if you have a solenoid sticking out of the trans with wires on it.
That's pretty crappy of him if he removed that from your trans.
Closed Thread
04:52 AM
