Changing cams - Mustang Evolution
Old 05-27-2012, 11:38 AM   #1
Changing cams
I want 2 put in a f303 cam was wondering if there is anything else I need to be change while im doing this....this is my first cam change so all advice appreciated
Stangcrazy1 is offline   Reply With Quote
Old 05-27-2012, 12:35 PM   #2
Re: Changing cams
Sure, heads, intake, injectors,................
Just inspect your lifters for any chipping or wear on the rollers, your pushrods to make sure they are not bent or damaged on the ends and your rocker arms to ensure the pushrod sockets are ok and the pivot point is ok.
You will also want to ensure your pushrods are of the correct length.
With the rocker arm installed and tightened down correctly you want the arm to contact the valve tip right in the middle of the tip.
If it is off to the side it side loads the valve stem and pushes it into the guide wearing it out fairly quickly.
Old 05-27-2012, 01:48 PM   #3
Got new intake and carb, should I just replace the lifters, push rods and rocker arms??
Old 05-27-2012, 02:11 PM   #4
Re: Changing cams
That's up to you, but if you are running the old, tired parts it would probably be a good idea.
05:39 PM
