My rear end is loose - Mustang Evolution
Old 05-27-2012, 06:22 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Jack the rear end up off both tires and can grab a tire and have it shift about a quarter of an inch just the rim and outside drum on the brakes nothing else moves? What is it and what can I do?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 05-27-2012, 06:48 PM   #2
Re: My rear end is loose
Nothing. That's just the slack in the axle.
When you pull on it it slides out until the C-clip stops it.
Old 05-27-2012, 11:46 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Okay that's what I thought. But I wasn't sure I posted a picture and I'm missing this on both sides !? I need help there's also two holes like on the frame not far from it but I feel dumb because I don't know..
2001 GT - True Blue
Old 05-27-2012, 11:52 PM   #4
i dont remember what mine looks like but i think thats where the quad shock goes. here is a pic of it, not mine but you can see.
all that does is help with wheel hop. lots of people remove them. alot of people wait to take them off until they get lower control arms.
Old 05-28-2012, 12:11 AM   #5
slow281
sixpac's Avatar
Region: Nebraska
Ii have my lower arms.. But I'm trying to figure out why my rear end feels so loose.. But yes I don't have that..
2001 GT - True Blue
Old 05-28-2012, 12:28 AM   #6
of course you have your lower arms. what im saying is its best to have upgrade lower arms when removing the quad shocks but not absolutly neccesarry.
if you read what trojan said it is normal to be able to move the tire in and out some. if you have ever looked insed a carrier where the axles go into to. there is a c clip on the end of the axle. thats all that holds the axle in. but it only hold the axle from coming out. there is a gap in between both axles right in the middle. so the axle can actually slide in a little bit. when you remove an axle from the housing you actually need to be able to slide it in a little bit to remove the clip. otherwise you wouldnt be able to get it off.
does your car not drive right? or are you just worried cause the axle slides in and out?
Old 05-28-2012, 12:38 AM   #7
slow281
sixpac's Avatar
Region: Nebraska
Yeah I get all that.. it seams like it sways when I let off the gas.. And I'm trying to figure that out..
2001 GT - True Blue
Old 05-28-2012, 12:41 AM   #8
ok just making sure. you never really can tell for sure what someone know or if they understand what your saying.
Old 05-28-2012, 12:44 AM   #9
slow281
sixpac's Avatar
Region: Nebraska
Ha yeah no I get what your saying would missing those quad shocks cause my car to sway or shift a little bit?
2001 GT - True Blue
Old 05-28-2012, 12:48 AM   #10
I don't think so. But I can't be sure on that. I didn't remove mine until I installed my umi lift bars.
Do you still have a rear sway bar? And are all your bushings in your rear suspension in food shape?
Old 05-28-2012, 01:32 AM   #11
slow281
sixpac's Avatar
Region: Nebraska
Bushings is a good question.. The sway bar is still there.. That's the only thing missing in the back. But all the arm controls are stock..
2001 GT - True Blue
Old 05-28-2012, 02:22 PM   #12
Most likely your problem stems from worn out, mushy control arm bushings. Replace the lower control arms with the UMI Lift Bars and uppers of your choice.
You will see and feel a marked improvement in your handling and traction.
P.S. My 86 GT sways from side to side whenever I press down on the gas pedal to far and I suddenly get the smell of burning rubber.
Never have figured out what that's all about?
Old 05-28-2012, 03:38 PM   #13
Loc: Austin,TX
Have you ever been to prison?
Old 05-28-2012, 03:40 PM   #14
Haha. That could definitely cause it.
Old 05-28-2012, 07:23 PM   #15
I thought 'too much fiber, poor guy'
1fst86 is offline   Reply With Quote
Old 05-28-2012, 08:27 PM   #16
You guys are sick!
Old 05-28-2012, 08:51 PM   #17
slow281
sixpac's Avatar
Region: Nebraska
Yeah well mines usually when I let off the gass for right now is it a bad thing to drive it as I'm on a limited budget?
2001 GT - True Blue
Old 05-28-2012, 08:58 PM   #18
You should get under there and make a visual inspection just to be sure nothing is broken or there aren't any bolts missing, but other than that you should be ok.
Old 05-28-2012, 09:15 PM   #19
slow281
sixpac's Avatar
Region: Nebraska
---------- Post added at 10:15 PM ---------- Previous post was at 10:01 PM ----------
I was under there last night looking around and I'm only missing the quad shocks on both sides everything else seams to be there and in tact, I should probably go under with a wrench and tighten everything but nothing was lose to the touch.
2001 GT - True Blue
Old 05-28-2012, 09:15 PM   #20
While your doing an inspection of the rear. Maybe check your motor mounts to? Is it possible the motor is twisting?
Old 05-28-2012, 09:34 PM   #21
slow281
sixpac's Avatar
Region: Nebraska
Could be but I think that be more noticeable on the accelorating end of it as well and I don't notice much there..
2001 GT - True Blue
12:02 AM
