Clutch??? - Mustang Evolution
Old 05-28-2012, 11:35 PM   #1
Moyhuerta's Avatar
Clutch???
My clutch make a cricket noise when i let go of the clutch peddel but wen i jenty puf my foot on the clutch peddel the noise stopes completly what would it might be???
Moyhuerta is offline   Reply With Quote
Old 05-28-2012, 11:46 PM   #2
93slowstang's Avatar
It's your throw out bearing. You probably need to adjust your clutch.
Old 05-28-2012, 11:57 PM   #3
Moyhuerta's Avatar
Im going to have to check that out becouse its been doing it for a whike and dat littel noise gets annoying.
Old 05-29-2012, 12:06 AM   #4
Yes it does. Just adjusted mine a couple months ago.
Old 05-29-2012, 12:08 AM   #5
Moyhuerta's Avatar
How could i do it myself???
Old 05-29-2012, 12:13 AM   #6
Does your car still have the stock quadrant? If so put it in gear with the car off and pull up on the clutch with the top of your foot.
If its aftermarket without a firewall adjuster you are going to have to get under the car and loosen the cable on the fork some.
Old 05-29-2012, 12:18 AM   #7
Moyhuerta's Avatar
Yea it is stock but what do u mdan pull it up wit my foot
Old 05-29-2012, 12:59 AM   #8
Re: Clutch???
just like i mean, the stock quadrant is adjustable.
Old 05-29-2012, 01:01 AM   #9
Moyhuerta's Avatar
But like how do i adjust it...sorry to give u a hard time im just confused
Old 05-29-2012, 01:07 AM   #10
It no problem at all. With it in gear, car off, put your foot under your clutch pedal and pull it towards you. It should click if it adjusts.
Old 05-29-2012, 01:12 AM   #11
Moyhuerta's Avatar
Oh kk i get u noe...i do it jeantly right or do i hav e to pull pretty hard
Old 05-29-2012, 01:17 AM   #12
Shouldn't have to pull too hard.
Old 05-29-2012, 01:20 AM   #13
Moyhuerta's Avatar
Oh alright....ill keep u updated if it worked or not
Old 05-29-2012, 11:09 PM   #14
Moyhuerta's Avatar
I try pulling it like how u said nd nothing happend it still does the same sound
Old 05-29-2012, 11:37 PM   #15
Re: Clutch???
Most likely your cable has stretched out past the point of adjustment.
If the quadrant has never been replaced with an aftermarket aluminum version I would replace it and the clutch cable and add a firewall adjuster too.
I prefer the OEM cable supplied by Maximum Motorsports as it is built the same as the factory cables and will outlast other aftermarket cables.
Old 05-29-2012, 11:39 PM   #16
You may have an aftermarket quadrant. You will have to climb under the car to adjust it if you don't have a firewall adjuster for the clutch cable.
Old 05-30-2012, 12:16 AM   #17
Moyhuerta's Avatar
Thanks for the tips im going to have to have to by the aftermarket one then nd u said the OEM is better to buy
Old 05-30-2012, 12:23 AM   #18
Re: Clutch???
Yes, read about it on the link I posted above.
Just click on Maximum Motorsports in that post.
04:13 PM
