Msd box - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-29-2012, 12:56 PM   #1
351mustang's Avatar
351mustang is unknown around these parts
Msd box
So I know that either they work or it doesn't work. However, what are some symptoms that it's not working can they vary? What I have going on is the feeling of lost timing the exhaust note has changed it back fires from the carb on first start up and you can see like specs of fuel shooting from the carb. I changed the carb and it ran a little better but still the exhaust note is the same and loss of power and still backfires from the carb. Any ideas?
351mustang is offline
Old 05-29-2012, 02:09 PM   #2
Senior Member
dreamstang is unknown around these parts
Definitely sounds like a timing issue. If you go to msd website there are testing procedure for the box. And also testing procedures in the sticky section.
What I would do is check your timing. Then if that don't help call msd and they will walk you through the testing procedures If needed. If they box is bad they will repair it from minimun 30$ to max 80$.
dreamstang is offline
Old 05-29-2012, 02:16 PM   #3
351mustang's Avatar
Ok thanks, also this all started when I used higher octane I didn't think that could effect anything.
Old 05-29-2012, 02:24 PM   #4
Senior Member
I doubt it but I suppose its possible. Definitely check your timing.
---------- Post added at 03:24 PM ---------- Previous post was at 03:19 PM ----------
Just a guess if it is the fuel, your timing is probably retarded to much.
Old 05-29-2012, 03:47 PM   #5
kylelvlss's Avatar
kylelvlss is unknown around these parts
Tfi module
kylelvlss is offline
Old 05-29-2012, 03:58 PM   #6
Senior Member
Originally Posted by kylelvlss
Tfi module
I'm not positive of his setup. But he is probably not running the tfi module with the carb.
Old 05-29-2012, 05:08 PM   #7
intensive's Avatar
intensive is unknown around these parts
Im pretty sure ive never seen thin film ignition in a carbed set up but i could be wrong.
---------- Post added at 07:08 PM ---------- Previous post was at 07:07 PM ----------
I had a 74 f100 that would spit fire up out the carb . And it was the timing just as dream stated above
intensive is offline
Old 05-29-2012, 07:12 PM   #8
351mustang's Avatar
That's what I'm thinking timing but not from the distributor right I mean that can't jump timing can it? The bolt is secure I checked that first to see if it was loose
Old 05-29-2012, 07:19 PM   #9
Filibuster
XXSTEVEO66 is unknown around these parts
Yes..it can ask Dreamstang bout that one!..
XXSTEVEO66 is offline
Old 05-29-2012, 07:26 PM   #10
Senior Member
I have lots of posts in my thread but I just had a similar problem. It was because I was getting intererance on my distributor wires. If you feel like reading it, it should be within the last few pages of my thread titled " what it takes" . Thread was posted on within the last few weeks so if you scroll down a few pages in this section you should be able to find it.
I still stay check timing. If it is off, reset it. Then Mark the distributor so you can rule that out if your timing moves again. Then if it does move again, msd tech will help you verify if the box is bad. And like I said before they are pretty cheap to repair versus buying a new one.
---------- Post added at 08:26 PM ---------- Previous post was at 08:23 PM ----------
Also what kind of distributor do you have. If its mechanical/centrifigul advance type there is a chance that the advance mechanism is getting worn. If the other thing I suggested check out ok and you still have problem, you maybe able to put new springs in the advance if you have that type.
Old 05-29-2012, 07:44 PM   #11
351mustang's Avatar
It's centrifugal but I forget the model number it's the one that says its specifically for the 351w victor jr intake which I have.
Old 05-29-2012, 07:46 PM   #12
Senior Member
If its old the spring could be worn. But for starter reset timing. Sorry if I sound like a broken record.lol But that's the first step to trouble shooting this.
Old 05-29-2012, 07:50 PM   #13
351mustang's Avatar
Just read the post. I will investigate that very well could be my issue which was stated in your thread" what it takes" I've had some issues with things vibrating lose ( not to happy with my engine builder) as we speak my car has been sitting there now for two weeks waiting for him to look at this issue as well as tighten everything up. Think it's time to move on from him
Old 05-29-2012, 07:53 PM   #14
Senior Member
Sounds like it. One other thing to remember. I carbed motors take a little bit more maintenance that an efi system. Good luck man. If you need anything else or can think of anything else let us know. I definitely let us know what you find out.
Old 06-30-2012, 12:31 PM   #15
351mustang's Avatar
Well I dropped a valve : sigh:
Old 06-30-2012, 11:20 PM   #16
Senior Member
Trojan Horse is just getting started.
Re: Msd box
Is your engine builder going to cover that?
Note: I'd replace all of the valve spring locks and retainers with 10° locks and retainers.
Trojan Horse is offline
Old 06-30-2012, 11:58 PM   #17
351mustang's Avatar
Yeah he is
Old 07-01-2012, 12:23 AM   #18
Senior Member
Re: Msd box
Yeah he is
That's good.
Did the valve pull through the retainer, break or what?
Old 07-01-2012, 12:29 AM   #19
351mustang's Avatar
That's good.
He just pulled the cover so we aren't sure the extent of the damage
Closed Thread
07:22 AM
