Coil packs/distributer caps - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-30-2012, 08:03 AM   #1
sixpac's Avatar
sixpac is unknown around these parts
Kay this is a more generalized question because I'm asking about my 01 v6 but it seam to be all the brains are on this thread.. I was thinking about getting a performance coil pack (screaming Demond) and a guy said he has and it help but he also said he was running a .065 gap (spark plugs) when stock calls for a .054... Ever heard of running diffrent gaps for diffrent packs or anything of the sort.. An info helps!!
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
sixpac is offline
Old 05-30-2012, 10:12 AM   #2
Senior Member
dreamstang is unknown around these parts
If you have aftermarket ignition parts you can get away with a hair bigger gap. But I personally don't see it necessary to go that big.
The theory behind a bigger gap is to get the spark more exposed to the fuel mixture. But when you run to large of a gap a risk not making the spark and are putting your ignition sources to harder work.
dreamstang is offline
Old 05-30-2012, 10:22 AM   #3
Titus Wadicus
svtlx's Avatar
svtlx is unknown around these parts
Re: Coil packs/distributer caps
+1
the larger gap will make the ignition system pull more amps. it can hurt the battery/alternator depending on the power draw. (i know cause i done it...lmao!)
thats an old school racer thing. mainly for keeping the plugs from fouling out at idle and low rpm cause of really large cam, on carbed cars. not necessary with todays igniton systems and efi.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
svtlx is offline
Old 05-30-2012, 10:40 AM   #4
sixpac's Avatar
Originally Posted by svtlx
+1
This guy claims to get better mpg with the screaming Demond coil pack.. But I don't want to hurt anything
sixpac is offline
Old 05-30-2012, 02:38 PM   #5
Senior Member
Trojan Horse is just getting started.
The Screaming Demon website claims better mileage and they tell you to open the gap up to .060 - .065, but like dreamstang and svtlx said it is harder on your ignition system. I'd keep it at the stock gap or just a few thousandths over at the most. To get the full benefits you should probably add the plug wires too.
I just read an article in a HP Mustang Performance Engine Tuning book where they installed the complete Screaming Demon Ignition (coil, module, cap, rotor and wires) on a stock Fox Body Mustang and picked up 3 HP and 3 ft lbs or TQ at the rear wheels on a dyno, so they proved it does help, BUT the 01 ignition is probably more efficient than the Fox Body ignition, so your results may be less or even non existent.
Trojan Horse is offline
Old 05-31-2012, 11:43 AM   #6
sixpac's Avatar
+1
I guess all these people are claiming to pull 30mpg+ out of there sixers and I'd sure like to know how. Unless they don't no how to calculate because the best I've ever seen from mine is 26.. So im looking for little things that might help and someone said coil packs.. Anything other ideas from the brains of the foxbody geniuses.
sixpac is offline
Old 05-31-2012, 12:15 PM   #7
Senior Member
+1
It's still not a bad idea to upgrade the coil. Doesn't mean you have to run some large plug gap. The best thing you can do is keep it properly maintained. Like fuel filter, injector cleaner, air filter, wires, plugs, etc etc. And even more importantly what effects mpgs the most is how you drive it.
Old 05-31-2012, 01:17 PM   #8
Senior Member
Keep your air filter clean, your tires properly inflated and don't carry around a bunch of extra weight. Those and good driving habits will net you the best mileage.
Closed Thread
12:00 PM
