Ok I have AFR 165s stock bottom end (1990 GT). With 1.6 roller rockers stock lifters does anyone have a clue on size and length pushrods imma need it's the one part I haven't bought cause I don't have a clue to what size and length I need. Should I get chrome moly or steel. Hardened or not. What do y'all recommend should I get guide plates come on I plan on putting my engine together next week. Any help is wanted and appreciated
You need to get a push rod length checking tool to ensure you get the correct length. There can be differences if the block was ever surfaced or decked so you cannot depend on what someone else might have used.
Chromoly, & Hardened, guide plates if you can use them.
I like the one piece myself and whatever diameter will work best with your guide plates.
Stock diameter should work fine, the aftermarkets are likely much stronger than the stock pushrods anyways. :good:
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
