Cardone ecc - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-01-2012, 09:24 AM   #1
Finchms's Avatar
Finchms is unknown around these parts
Cardone ecc
Has anyone used this computer? Are they any good? Give any problem? Autozone sells a few different ones. 76-4352 is part number. This the same as the a9l? Thanks for the help
Finchms is offline
Old 06-01-2012, 09:40 AM   #2
Titus Wadicus
svtlx's Avatar
svtlx is unknown around these parts
Re: Cardone ecc
i have a 95 pcm i bought from there. no issues...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
svtlx is offline
Old 06-01-2012, 04:32 PM   #3
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
The cheapest one is them rebuilding yours and sending it back. I had mine rebuilt from them about a year ago and have no problems from it. Took about a month though.
93slowstang is online now
Old 06-01-2012, 09:53 PM   #4
5.8GT's Avatar
5.8GT is unknown around these parts
I have a cardone ecc in my car and I have not had any problems.
5.8GT is offline
Old 06-02-2012, 08:18 AM   #5
Finchms's Avatar
I like to go the cheaper route but i really can't wait a month though. Its my dd so i can't be without. Lol do yall have this part number i mentioned or different? I ask cause there being a few different ones i didn't know if they are any difference.
---------- Post added at 09:18 AM ---------- Previous post was at 09:12 AM ----------
I apologize. That part number is a 78-4352.
Finchms is offline
Old 06-02-2012, 10:53 AM   #6
Moderator
Just go up there and make sure it's not an R&R (repair & return) part. Are you sure your ecc is bad?
Old 06-05-2012, 08:18 AM   #7
Finchms's Avatar
Yeah. I was having bad issue with the idle. I checked and cleaned all the usual and finally done a koeo test. It gave me a code 19 which has to do with computer. So i researched it and it wound up being the computer. I went ahead and got one from autozone and it runs like a top. No more issues so far.
Finchms is offline
Closed Thread
07:18 PM
