filler neck... - Mustang Evolution
Old 06-02-2012, 05:56 AM   #1
Blackbeauty95's Avatar
filler neck...
So my filler next for the gas tank is freaking rusting out and if i fill it all the way up it reeks like gas... anyone ever have this problem and have any idea around how much those cost or where to get a good deal on one? Thanks Terry
---------- Post added at 05:56 AM ---------- Previous post was at 05:56 AM ----------
Neck*
Blackbeauty95 is offline   Reply With Quote
Old 06-02-2012, 06:11 AM   #2
Filibuster
Im gunna make an uneducated guess here and say the ”filler neck” is rubber and your leak is coming from the joint of your gas cap and ”filler neck”....or at the tank..maybe someone replaced a fuel pump and damaged the neck?.
Plus gas stations usually say ”do not top off”
XXSTEVEO66 is offline   Reply With Quote
Old 06-02-2012, 06:13 AM   #3
Thats not topping it off lol and when i looked i didn't see any rubber up there it is an after market tank cause its plastic and looks like its new
Old 06-02-2012, 06:27 AM   #4
Filibuster
You sure its an aftermarket tank?...im guessing your stock tank is plastic..if it looks clean that probably means someone did change a fuel pump or fiddled with something..
Is your car set up for any kind of racing?..thats the only way somebody would put a different tank in..and it would most likely be in the trunk.
Old 06-02-2012, 06:42 AM   #5
No its in the stock place... maybe this is just a reason to throw a fuel cell in ;p lol
Old 06-02-2012, 10:31 AM   #6
There you go!
Old 06-02-2012, 10:50 AM   #7
93slowstang's Avatar
You sure the tank is plastic? The cover that goes over your tank is but the tank should be metal.
Old 06-02-2012, 11:28 AM   #8
Yeah the whole thing is plastic, thats why i was assuming it was already replaced.
Old 06-08-2012, 09:24 AM   #9
So no one has any ideas on how to fix this problem?
Old 06-08-2012, 09:50 AM   #10
If its just a small leak try some epoxy. You can pick it up at your local auto parts store. Just make sure you clean it good.
Old 06-08-2012, 06:20 PM   #11
Thanks dreamstang
Old 06-08-2012, 06:20 PM   #12
your welcome.
« Rear seal | Exhuast »
09:11 AM
