Leaking oil - Mustang Evolution
Old 06-02-2012, 08:14 AM   #1
slow281
sixpac's Avatar
Region: Nebraska
Leaking oil
My 5.0 leaks oil but only when it's running? And shortly after.. But wont leave a puddle if it's just sitting..? :Confused: :S
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-02-2012, 08:25 AM   #2
05MUSTANG4.0L's Avatar
Change they oil pan screw
05MUSTANG4.0L is offline   Reply With Quote
Old 06-02-2012, 08:32 AM   #3
slow281
sixpac's Avatar
Region: Nebraska
I'll do that but I feel like its coming from higher. I did have a camaro once (ik shame on me) that did the same thing and it was like the oil pressure something or another..
2001 GT - True Blue
Old 06-02-2012, 08:53 AM   #4
WhiteCobra94's Avatar
Change the oil pan gasket to, check the drain plugs
Old 06-02-2012, 10:12 AM   #5
I would get under there and degrease everything really good. The with it running get back under there. It will be a lot easier to pinpoint the leak.
Old 06-02-2012, 10:15 AM   #6
A major gasket maybe
Old 06-02-2012, 10:43 AM   #7
Forum Car Trader
90GTNovi2000's Avatar
Do what dream said further pin point the leak and we can help you figure it out.. Or lay a piece of card board down and see.. Is it the left rear, right rear, center rear, up front etc..
---------- Post added at 11:43 AM ---------- Previous post was at 11:41 AM ----------
It could be a valve cover gasket or something higher since you said it only leaks after running which
---------- Post added at 11:43 AM ---------- Previous post was at 11:43 AM ----------
Makes me guess the top end of motor or rear seal or something..
90GTNovi2000 is offline   Reply With Quote
Old 06-02-2012, 12:20 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Rear seals suck...... Ha
2001 GT - True Blue
Old 06-02-2012, 03:29 PM   #9
Re: Leaking oil
Check your oil pressure sending unit. Sometimes they develop a leak between the plastic/phenolic insulator and the metal body.
Old 06-02-2012, 07:29 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
I'm guessing that's nor the same thing as the oil pressure switch that I just bought?
2001 GT - True Blue
Old 06-02-2012, 07:46 PM   #11
Re: Leaking oil
Well I don't know what you bought, but if it is the sending unit from the driver's side front of the engine about halfway down the front of the block, then yes.
06:51 PM
