Fuel pump - Page 2 - Mustang Evolution
Old 06-07-2012, 07:00 PM   #36
yes you can just push it in. thats also where you should be checking pressure.
Old 06-07-2012, 07:08 PM   #37
Quball19's Avatar
I have a pressure gage on rails
---------- Post added at 07:08 PM ---------- Previous post was at 07:01 PM ----------
Getting fuel to schrader. With key on if comes out. Not sure how much pressure
Quball19 is offline   Reply With Quote
Old 06-07-2012, 07:09 PM   #38
well check it at the valve. if you have pressure there then your problem is in that area.
Old 06-07-2012, 07:25 PM   #39
Filibuster
If you have a gauge on the rails what does it read?..I have a gauge directly off the schrader valve..that is prior to the regulator so that should read what the fuel pump is feeding through the lines..
XXSTEVEO66 is offline   Reply With Quote
Old 06-07-2012, 07:30 PM   #40
Old 06-07-2012, 07:49 PM   #41
Maddhatter88's Avatar
If it getting fuel all the way up the. I'd say start looking at the injector connections or injectors period. That is if ur FI.
Maddhatter88 is offline   Reply With Quote
Old 06-08-2012, 04:01 AM   #42
Quball19's Avatar
Gage on rails reads "zero"or just above that.
Old 06-08-2012, 04:37 AM   #43
Like Steve said. Now check the shrader valve. If you have pressure there but not on the rail, its probably gonna be the regulator.
Old 06-08-2012, 04:39 AM   #44
Quball19's Avatar
I will check tonight
Old 06-08-2012, 04:41 AM   #45
Let us on now what u got.
Old 06-08-2012, 04:49 AM   #46
Quball19's Avatar
I will have to rent fuel gage from auto store to check at schrader...
Old 06-08-2012, 05:54 AM   #47
Whatever it takes.
Old 06-08-2012, 07:46 AM   #48
Filibuster
^I see what you did there..
Old 06-08-2012, 08:00 AM   #49
Quball19's Avatar
Confused?? Did where?
Old 06-08-2012, 08:22 AM   #50
Forum Car Trader
90GTNovi2000's Avatar
Lol whatever it takes.. Dream was quoting himself!!! Inside joke..
---------- Post added at 09:21 AM ---------- Previous post was at 09:18 AM ----------
It sure sounds like the regulator if the gauge is at zero and the pump is working.. But you will know as soon as you check your shreader valve
---------- Post added at 09:22 AM ---------- Previous post was at 09:21 AM ----------
Schrader**
90GTNovi2000 is offline   Reply With Quote
Old 06-08-2012, 11:11 AM   #51
Quball19's Avatar
Ok I give!!!!! Thanks
---------- Post added at 11:11 AM ---------- Previous post was at 10:50 AM ----------
One more quetion.... If relay is bad will pump turn on?
Old 06-08-2012, 11:20 AM   #52
Forum Car Trader
It could and turn right back off shortly after..
Old 06-08-2012, 11:24 AM   #53
Stang.racr's Avatar
This
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-08-2012, 04:50 PM   #54
when you turn the key forward the pump will run for 2 seconds then shut off until you go to start the car. the relay get the signal from the ecu via the tfi module. now i dont know what controls the 2 second prime but i would think its possible like the guys said.
Old 06-08-2012, 05:10 PM   #55
Quball19's Avatar
Just returned fuel regulator, new one gets here tuesday. I am getting fuel to railsby just turning the key on then off real quick. So waiting on regulator,like you said in previous post. The good thing is it didn't cost me nothing but time. It was only 3 months old. I let you know how turns out...... Angry
Old 06-08-2012, 05:26 PM   #56
so your saying the pump is priming. but will the pump stay running once you start it? if not you have another issue.
Old 06-08-2012, 05:35 PM   #57
Yea the pump has to prime when u first turn the key over. It will not stay running. It just does it to keep the pressure up on start up. Take the line lose at the regulator and turn the switch over like ur cranking it and see if it pumps has out of the line. If so then unhook the other side of the regulator and see of its punching threw it if so then it's gonna be in the rails or the actual injectors
---------- Post added at 06:33 PM ---------- Previous post was at 06:33 PM ----------
I mean gas
---------- Post added at 06:35 PM ---------- Previous post was at 06:33 PM ----------
I mean pushing not punching (damn IPhones)
Old 06-12-2012, 04:14 PM   #58
Quball19's Avatar
Ok new pump, filter, relay, regulator.
Still no go..pressure gage pumps up to pressure then bleeds off... Really like to get running... Please anybody.
Just sits and cranks
Old 06-12-2012, 04:29 PM   #59
I wonder if its the tfi module? Test that and see if its good. If its bad your pump will still prime. But the tfi sends signal to the ecu to run the pump. Don't just change it though. You need to do some testing.
Old 06-12-2012, 04:32 PM   #60
Quball19's Avatar
Tfi module ? Please tell me where its at?
Old 06-12-2012, 04:38 PM   #61
It's on the distributor. Some people call it ignition module.there should be a testing procedure in your Haynes/chilton. Now this is just a guess, so make sure you test it.
Old 06-12-2012, 04:44 PM   #62
Quball19's Avatar
Ok, I will
Old 06-12-2012, 05:34 PM   #63
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
If you take it off you should be able to take it to advance and they can test it if you can't. I think it's 2 5/16 screws holding it to the distributor then once those are out slide it down. Don't just unbolt it and try to pull it straight away from the dist. It has 3 little prongs that slide up into the dist.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-12-2012, 05:37 PM   #64
Quball19's Avatar
Thanks for input. I will do that.
Old 06-12-2012, 06:23 PM   #65
Quball19's Avatar
Got if off with no issues, taking it to work tomorrow to check. Ill let you know. Thanks
Old 06-13-2012, 05:51 AM   #66
Quball19's Avatar
Ok checked tfi, checked good. Going to check coil, and guess everything...
Lost
Old 06-13-2012, 07:24 AM   #67
Ok. Let's recap. You changed pump and relay?
Did you check fuel pressure? If so what you got?
Is it firing? Is the pump running? Do you have 12 volts at the pump?
---------- Post added at 08:24 AM ---------- Previous post was at 08:23 AM ----------
Also check the pip/hall sensor
Old 06-13-2012, 07:31 AM   #68
Quball19's Avatar
Yes new pump, filter, relay. Getting preasure at gage(now) on rails when gets pumped up gets to 35-40, then slowly drops with key on. Pump is kicking on.
Old 06-13-2012, 08:58 AM   #69
Quball19's Avatar
If I may start from beginning.....
Was driving car night before indy 500, left a buddies house to go to other. On the way car ran good, then I look at tach(both) stock, and 5". The needle was bouncing around,going up and down while car was driving. Got to next place it was dead. As we were leaving got a jump start ran for one block stopped.towed home.(figured alternator). Took alternator had checked they said bad, put new one on. Would not start after.thats when everybody said fuel pump. Now here we are. Not sure if anything from alternator caused? What causes tach to jump like that?
Old 06-13-2012, 09:28 AM   #70
When I get home I will do some research. The tac is hooked somewhere into the ignition system, maybe coil ground.
07:53 PM
