Fuel pump - Mustang Evolution
Old 06-02-2012, 04:12 PM   #1
Quball19's Avatar
Fuel pump
What do you all suggest to be the best fuel pump? I hear walbro 255. Like your alls thoughts.
Quball19 is offline   Reply With Quote
Old 06-02-2012, 04:14 PM   #2
wlabros usually do the trick. a 190 will be fine though unless you plan on forced induction. unless you plan on getting real serious. but either way it wont hurt to go big.
Old 06-02-2012, 07:29 PM   #3
Re: Fuel pump
+1 What he said. A to large pump will just over circulate and warm up the fuel, which is not a good thing with gasoline.
Walbro makes most of the fuel pumps anyways, so you are good to go with them.
Old 06-03-2012, 04:25 PM   #4
Quball19's Avatar
Ok went to drop tank,this is probably stupid but hey, does it take a special wrench to get drivers side bolt off? You can see it from a hole in hatch, but it sits in there to where you can't get a wrench on it .confused....... I know should be easy just can't get to it.any suggestion?
Old 06-03-2012, 04:27 PM   #5
Re: Fuel pump
Sorry, it's been too long since I last removed a fuel tank, can you get us some pics of the issue?
Old 06-03-2012, 04:33 PM   #6
Quball19's Avatar
First pic is of hole in hatch. Second is bolt
Old 06-03-2012, 04:34 PM   #7
Quball19's Avatar
Well pics out of order
Old 06-03-2012, 04:40 PM   #8
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
If I'm remembering right there should just be 2 bolts between the axle and tank. Remove the filler neck and take out the 2 bolts holding the tank straps under the car.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-03-2012, 04:44 PM   #9
Quball19's Avatar
Yes, found them, one you can get topassenger side easy, other is a pita, can't get to bolt on top as pics show. Wrench won't go in to seat on nut
Old 06-03-2012, 04:45 PM   #10
Forum Car Trader
90GTNovi2000's Avatar
The filler neck hose bracket and the 2 bolts that hold the straps up that's it... It all comes out from the bottom
90GTNovi2000 is offline   Reply With Quote
Old 06-03-2012, 04:49 PM   #11
Quball19's Avatar
Yes, yes I know this ..... But can not get to (BOLT) that the nut is on. That is problem. Can't get wrench on it ...
It is a nut and bolt on drivers side strap
Old 06-03-2012, 04:50 PM   #12
Forum Car Trader
I have a few old pics of a fuel pump install.. It took a little over an hour to do.. It's not to bad!!
ID:	53097   Click image for larger version
ID:	53099   Click image for larger version
Old 06-03-2012, 04:52 PM   #13
Forum Car Trader
Really so someone added a nut and bolt?? I'm sure you know what you are doing I'm just not understanding... When it stock it's much easier
Old 06-03-2012, 04:53 PM   #14
Quball19's Avatar
Yes, I don't know how the heck they got bolt in there
Old 06-03-2012, 04:54 PM   #15
Forum Car Trader
Maybe you can get lucky and hit it quick and with force and bust it loose.. Also a buddy to hold it still with like a flat head screw driver or whatever you can hold it still with.. But you will prob need a hand
Old 06-03-2012, 04:57 PM   #16
Quball19's Avatar
Trying to get something in there, I even bent a wrench to fit in there but hard to hold
Old 06-03-2012, 05:20 PM   #17
Re: Fuel pump
Do you have a "crow foot wrench" ?
It is an open or closed wrench that fits on the end of a ratchet or extension.
It may be easier to just open up the hole and then find a bigger chassis hole plug when you are done.
Old 06-03-2012, 05:26 PM   #18
Quball19's Avatar
Yes do have crows foot but can't get head in hole. Bigger hole was last option, but looks like have to resort to it
Old 06-03-2012, 05:50 PM   #19
Re: Fuel pump
Looking at the pics I really don't see any alternative.
If you have a body or chassis plug available I would try to size it to fit if possible.
Old 06-03-2012, 05:52 PM   #20
good idea!
Old 06-03-2012, 05:54 PM   #21
Quball19's Avatar
Do have plug, was thinking drilling another hole right above it, then plug. Might looks little better you think?
Old 06-03-2012, 05:56 PM   #22
that should work good.
i would also try to mount it factory on reinstallation so if you have problem again the job will be easier
Old 06-03-2012, 05:59 PM   #23
Quball19's Avatar
I will thanks
---------- Post added at 05:59 PM ---------- Previous post was at 05:57 PM ----------
I will thanks
But will also have hole for this way too Lol
Old 06-03-2012, 06:02 PM   #24
I will thanks
true! haha
Old 06-07-2012, 05:07 PM   #25
Quball19's Avatar
Ok replaced fuel pump, filter, still no pressure. Any ideas?
Old 06-07-2012, 05:23 PM   #26
is the pump running?
Old 06-07-2012, 05:25 PM   #27
Quball19's Avatar
Yes
Old 06-07-2012, 05:26 PM   #28
pull the fuel line off at the filter and see if you get fuel there. and check for kinked lines.
Old 06-07-2012, 05:37 PM   #29
Quball19's Avatar
Pulled line lots of gas, didn't seen no kinks
Old 06-07-2012, 05:55 PM   #30
well unhook the next farthest forward part of the line you can. keep doing this until you dont get fuel then you should be able to pinpoint it. maybe regulator?
Old 06-07-2012, 06:01 PM   #31
Quball19's Avatar
Wow hope not brand new regulator
---------- Post added at 06:01 PM ---------- Previous post was at 05:58 PM ----------
Is the line going to regulator main fuel, or front of rails?
Old 06-07-2012, 06:03 PM   #32
imdont rrmember the exact setup. i am carbed. but i was saying that maybe the next spot to disconnect.
Old 06-07-2012, 06:06 PM   #33
Quball19's Avatar
Let me ask this .......alternator went bad unhooked battery to charge ,could this have any to effect this issue? Wouldn't think so but just asking
Old 06-07-2012, 06:30 PM   #34
i doubt it. but i guess anythings possible.
Old 06-07-2012, 06:58 PM   #35
Quball19's Avatar
Can you check if any fuel on schrader valve ? If soon do you just push in like a tire valve?
06:57 AM
