Originally Posted by word827 I'm looking for new rims for my 1988 LX 5.0. I like the look of Weld rims and I also want the rear end to sit a little higher than the front. Anyone know of a good website to get Weld rims and has anyone raised the rear by putting a bigger rims on the rear and keeping a 15" on the front ones? |
You really don't want to oversize the diameter of your rear tires much it will throw off the speedo and be difficult to correct.
Originally Posted by dreamstang If that's what you want I would just lower the front an 1" .then you can get the same size rims. Summit racing has a good selection of weld rims. |
That's good advice.
Originally Posted by Mady What about these rims? |
Very nice, but most of our cars are 4-lug and I don't think it looks right to have a 5-spoke wheel on a 4-lug bolt pattern. Converted to 5-lug though they look great.
Originally Posted by 90GTNovi2000 Yes I would search your local Craigslist for some... Average price would be around $575 for a good set with used tires.. A 275/50/15 should clear fine on. 4.5" or up to a 6.5" backspacing with a skinny 195 up front should give you a decent stance.. I have a few examples..
That's my old 93' stock suspension with the weld setup.. |
Originally Posted by 90GTNovi2000 This is my 88' with Lakewood drag setup on it.. The 6.5" backspacing rim like this one will pull the rim and tire up under the car if you have a racing suspension.. I ran 28x11.50x15 m/t et streets.. |
Draglites FTW!
