Originally Posted by 88gtCc When I got into my car to start it, I pressed down on the clutch and I felt like I broke something...alas when I went to check, my pedal went straight to the floor with no resistance pushing back against me. I looked under the dash (and in my manual) and I have zero idea what I could have done or what I broke. If anyone could give me any advice as to what to look for or what I need to do to fix this issue that would be greatly appreciated  |
You probably broke your clutch cable.
Get you a Chilton's or Haynes manual.
They will have the replacement procedure.
I recommend the
OEM style cable from Maximum Motorsports.
It is much better made and will last longer than other aftermarket cables.
You may want to consider replacing the plastic factory quadrant, adding a firewall adjuster and doing the
Clutch Cable Freeplay Mod while you are at it.
