Engine question - Mustang Evolution
Old 06-03-2012, 09:42 PM   #1
Zacm90gt's Avatar
Engine question
Okay my car being a 1990 it has quite a few miles on the motor how can I make the motor better as in able to take more high performance action and Mabey even forced induction
Zacm90gt is offline   Reply With Quote
Old 06-03-2012, 09:43 PM   #2
Storm13_5.0's Avatar
Vortec super chargers seem to be a popular choice
Storm13_5.0 is offline   Reply With Quote
Old 06-03-2012, 09:43 PM   #3
WhiteCobra94's Avatar
How many miles?
Old 06-03-2012, 09:48 PM   #4
Zacm90gt's Avatar
110000
---------- Post added at 08:46 PM ---------- Previous post was at 08:46 PM ----------
I'm Afriad to even really hot rod it a lot you know
---------- Post added at 08:48 PM ---------- Previous post was at 08:46 PM ----------
If I sc I'm gonna go kenne bell blozilla 2.1 l
Old 06-03-2012, 09:48 PM   #5
110000
Yea you can start upgrading it but you don't know how long it'll hold up before she goes!!
Old 06-03-2012, 09:50 PM   #6
Zacm90gt's Avatar
How do I prevent the before it goes
Old 06-03-2012, 09:51 PM   #7
Build her up!
Old 06-03-2012, 09:51 PM   #8
Zacm90gt's Avatar
Like heads rods cam and all that
Old 06-03-2012, 09:57 PM   #9
Well I just finished my build, my car was pretty much bone stock for the first 7 years I had it, 169,000 miles and I bought heads, cam and intake , then my brother talked me into getting a shortblock and I'm glad I did because my pistons , rings bearings all were shot !
Old 06-03-2012, 10:00 PM   #10
Re: Engine question
See the "Superchargers & Turbochargers" sticky thread for engine building tips.
Old 06-03-2012, 10:03 PM   #11
It's 50 / 50 lol
Old 06-03-2012, 10:04 PM   #12
Zacm90gt's Avatar
Okay so I can keep my block have it bored out new heads (or can I just port polish my stock ones) gaskets bolts piston rings bearings cam intake or is stock alright ?
---------- Post added at 09:04 PM ---------- Previous post was at 09:04 PM ----------
Okay I'll check that out
Old 06-03-2012, 10:08 PM   #13
To do FI on that old of a engine u will most likely need new internals for this i recommend a stroker kit that comes with a forged parts also new heads and cams as well as LT headers other then that if u get a root style u won't need a new intake but if it's a centri get a new intake ,intake plenum, and throttle body
Mady is offline   Reply With Quote
Old 06-03-2012, 10:14 PM   #14
Zacm90gt's Avatar
Okay roots is better in low end right
---------- Post added at 09:14 PM ---------- Previous post was at 09:09 PM ----------
And where would you buy this kit
Old 06-03-2012, 10:15 PM   #15
Root style has power from idle since its run off the engine belt also for your year I'm not sure look up torq teck super chargers and u shall find what u seek
Old 06-03-2012, 10:17 PM   #16
Zacm90gt's Avatar
Okay thanks Mady you've been a lot of help
Old 06-03-2012, 10:18 PM   #17
Idk if torqu teck makes it for that year but type in the year u have and mustang root style blower and u should find something if not turbo it since u have the forged internals already
Old 06-03-2012, 10:19 PM   #18
Here's the price list from Kenne Bell
http://www.kennebell.net/KBWebsite/P.../PriceList.pdf
Old 06-03-2012, 11:05 PM   #19
Dang not cheap at all/:
Old 06-03-2012, 11:32 PM   #20
Re: Engine question
There is no "cheap" when it comes to adding that much HP.
"How fast do you want to go or how much power do you want to make?"
Always ends with "How much do you want to spend?"
Old 06-03-2012, 11:52 PM   #21
True that! Just never knew how much a kenne bell was ... I'm sure it's damn worth it tho
Old 06-04-2012, 12:05 AM   #22
Re: Engine question
Yes, I would too if I could afford a good aftermarket block and forged internals to go with it.
Old 06-04-2012, 12:10 AM   #23
Nothing like the whine of a kenne bell!
How much would a build for a kenne bell be like 12 G's
Old 06-04-2012, 12:31 AM   #24
Re: Engine question
Depends on whether or not you could do the assembly yourself and whether or not you had to buy all of the top end too.
Probably 6 - 10K anyways.
Old 06-04-2012, 01:01 AM   #25
Zacm90gt's Avatar
Could I use forged internals stage 3 street fighter to be exactly with stock block new heads intake throttle body pushrods cam and crank and turbo charge and be okay
---------- Post added at 12:01 AM ---------- Previous post was at 12:01 AM ----------
Or do I new aftermarket block
Old 06-04-2012, 03:08 AM   #26
TtownMach1's Avatar
Check out these sites. MMR has a special going on right now.
http://www.dssracing.com/category_s/171.htm
http://www.modularmustangracing.com/...hortblocks.htm
If the block is in good shape you'd probably be safe with just rebuilding it. Also depends on how much power you want to make. If you'r wanting to go FI also then may as well invest in a shortblock. Just my
5-Speed-IUP, Predator tuned, k&n cai,Mrt shifter,Hooker Lts-o/f x-pipe, KC clutch,Alum flywheel,FR 4:10's. Upr rear control arms. Forged Teksid Eaton swap in progress!
WickedStangs Mustang Club
Tulsa,OK Chapter President
TtownMach1 is offline   Reply With Quote
Old 06-04-2012, 08:42 AM   #27
So its really not to hatefull
01:29 AM
