gas question - Mustang Evolution
Old 01-29-2008, 12:16 PM   #1
gas question
i just bought a 95 mustang gt what kind of gas does it use?
thanks
95blackgt is offline   Reply With Quote
Old 01-29-2008, 12:25 PM   #2
Re: gas question
The cheapest you can find...
Old 01-29-2008, 01:53 PM   #3
Y2E0L0L5OGWT's Avatar
Re: gas question
I would assume 87 if it hasnt been tuned or worked on if it is still the stock setup
Old 01-29-2008, 08:51 PM   #4
Scut95's Avatar
Re: gas question
As long as its not tuned for higher octane or if your timing isn't advanced you can run 87 no problem.....when i bought my car the previous owner had the timing at 12 degrees and it needed 93 or it would ping.
Old 01-29-2008, 09:26 PM   #5
MonteCitan's Avatar
Re: gas question
5.0's don't care at all, unless you have it modded or bumped timing...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-29-2008, 10:50 PM   #6
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: gas question
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 01-30-2008, 07:08 AM   #7
Re: gas question
if its stock and not messed with (timming wise) you should be fine on regular 87. Just listen for detonation (marbles rolling around like sound in your upper intake area) then you can bump it up. It wont make ANY difference to run higher octane gas if the car isnt setup for it.
Old 01-30-2008, 09:15 AM   #8
Re: gas question
diesel!
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 01-30-2008, 12:06 PM   #9
Re: gas question
Originally Posted by Mustangfan2003 View Post
diesel!
dont forget to unplug the spark plugs if you go diesel cuase diesels dont need them!!
Old 02-01-2008, 08:14 AM   #10
Herbstang's Avatar
Re: gas question
:rofl:
Old 02-01-2008, 09:11 AM   #11
iwannagofast's Avatar
Re: gas question
unleaded
iwannagofast is offline   Reply With Quote
Old 01-14-2011, 12:48 AM   #12
94 Mustang GT's Avatar
Re: gas question
Diesels need spark plugs, goofy!!!! Oh btw that reminds me I need Royal Purpule blinker fluid for my ca!
94 Mustang GT is offline   Reply With Quote
Old 01-16-2011, 01:47 PM   #13
06mustangmike's Avatar
Re: gas question
regular, no need for higher octane unless informed by previos owner.
06mustangmike is offline   Reply With Quote
Old 01-17-2011, 06:38 AM   #14
Qwik Four Six's Avatar
Yea, I'm wondering the same. My car has a cam and some other things, not sure if the timing is advanced or not. I might call the guy back and ask.
Qwik Four Six is offline   Reply With Quote
Old 01-17-2011, 07:43 AM   #15
Re: gas question
yea see what the timing is, if you have detonation as well up the octane or reduce timing
Old 01-17-2011, 07:51 AM   #16
Alright. I'll see though. Thanks.
Old 01-17-2011, 01:20 PM   #17
Re: gas question
How aggressive is the cam? What other things? I personally would put a little higher octane in it until you find out what exactly is all under the hood, that why you can safer than sorry for like 5 extra bucks! Your timing isnt the only thing that determines what octane to use, so keep that in mind also!
Old 01-17-2011, 03:25 PM   #18
I know timing isn't the only thing. I know what's done to the car but I'm not sure about the type of cam.
Old 01-17-2011, 04:39 PM   #19
Re: gas question
good luck
Old 01-17-2011, 06:12 PM   #20
Originally Posted by 06mustangmike
good luck
Thanks.
i gotta question about gas Kyle The Bar 14 11-04-2005 11:48 PM
gas milage question fast64 Pre-2005 V6 Mustang 6 08-04-2004 06:16 PM
01:08 PM
