Noob question.. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-03-2012, 09:53 PM   #1
Senior Member
fast 94 5.0 is unknown around these parts
Noob question..
This is not my first post..i forgot my info for my last login. Anyway, once ina while when im doing a run ill miss 3rd bc I had a bad shift n.ill get a lil grind like normal n a high rev only for a second bc I fix my.mistake quick...now, can that damage my tranny/motor ina bad way? It only happens say 2 outta 20 runs
fast 94 5.0 is offline
Old 06-03-2012, 09:55 PM   #2
Senior Member
Mady is unknown around these parts
I wouldn't worry about it just don't let it grind if u can help it and that'll save the gears in the tranny lol and just get better at shifting start out shifting slow before shifting faster so the 2-20 becomes 20-20
Mady is offline
Old 06-03-2012, 09:59 PM   #3
Senior Member
Yea I push clutch in quick n pull shifter back..ill get a grind for like a half second..nothin major..just thought I ask..
Old 06-03-2012, 10:00 PM   #4
Senior Member
Practice makes perfect?
Mady is offline
Old 06-03-2012, 10:42 PM   #5
Senior Member
Trojan Horse is just getting started.
Re: Noob question..
Yes it can.
Over revving the engine during missed shifts can cause engine damage.
Grinding the gears together produces minute metal particles which get spread throughout your transmission.
Get a good aftermarket shifter like the Pro 5.0 that is designed to prevent over travel of the shifter forks which will bend them and they are designed to help prevent missed third gear shifts.
Trojan Horse is offline
Old 06-04-2012, 05:28 AM   #6
Senior Member
It only happend like 4 times since I had the car..(about a year) u dont think any crazy damage was done?
Old 06-04-2012, 06:29 AM   #7
Senior Member
dreamstang is unknown around these parts
Probably no damage if its only happened a few times. But I would suggest the pro 5.0 like trojan mentioned. It will help hitting the 3rd gear. It's also possible you may need an adjustment on your clutch.
dreamstang is offline
Old 06-04-2012, 07:58 AM   #8
Senior Member
Ok cool..thanks,ill look into it
Old 06-04-2012, 08:29 AM   #9
Storm13_5.0's Avatar
Storm13_5.0 is unknown around these parts
Is the steeda tri ax any good ?
Storm13_5.0 is offline
Old 06-04-2012, 09:01 AM   #10
captain78's Avatar
captain78 is unknown around these parts
Steeds tri ax is a great shifter but I fell in love with the MGW shifter. I've shifted both and IMO MGW is a better shifter. Tighter smoother guarantee not to ever miss 3rd again and life time warrantee on all parts of shifter. Plus you can rotate the handle 360 degrees to suit you better
captain78 is offline
Old 06-04-2012, 09:47 AM   #11
Hmm sounds better to me lol.. Can you send me a link man? Please
Old 06-04-2012, 09:55 AM   #12
Senior Member
Price??
Old 06-04-2012, 12:02 PM   #13
captain78's Avatar
http://www.mgwltd.com/mustang_shifter.shtml
Here you go
---------- Post added at 01:02 PM ---------- Previous post was at 12:59 PM ----------
$185 for the T5/t45. $209 TKO500/600
Old 06-04-2012, 12:13 PM   #14
Here you go
Thanks a lot !!
Old 06-04-2012, 01:27 PM   #15
captain78's Avatar
No problem
Closed Thread
01:11 PM
