06-04-2012, 12:06 AM
#1 | | Registered User
| Gears 3.73
So i Installed my new gears 3.73into my car and everything is fine beside when I start going over 60 my car starts to shake a lot it used to do that as well but not after 60 but like hitting 85 and over with the stock gears what could be causing this to my car can't really stand the shaking and I have to use the freeway quite a lot
06-04-2012, 12:32 AM
#2 | | Registered User
| Quote: |
Originally Posted by Jbeas50 So i Installed my new gears 3.73into my car and everything is fine beside when I start going over 60 my car starts to shake a lot it used to do that as well but not after 60 but like hitting 85 and over with the stock gears what could be causing this to my car can't really stand the shaking and I have to use the freeway quite a lot | Honestly it could be many things. Driveshaft problem; tranny problem, hubs, tires... A lot of things. A
06-04-2012, 01:10 AM
#3 | | Registered User
Do you feel a vibration besides the car shaking coming from somewhere in particular? Under your feet, or rear of car maybe. Check the u-joints.
5-Speed-IUP, Predator tuned, k&n cai,Mrt shifter,Hooker Lts-o/f x-pipe, KC clutch,Alum flywheel,FR 4:10's. Upr rear control arms. Forged Teksid Eaton swap in progress! WickedStangs Mustang Club Tulsa,OK Chapter President |
06-04-2012, 10:03 PM
#4 | | Senior Member
| Re: Gears 3.73
It may be that your driveshaft is out of phase.Disconnect it, roll it over 180° and put it back in.
__________________ |
06-05-2012, 01:37 PM
#5 | | Registered User
I lifted my car today it looks like my tranny is lose it was missing some bolts
06-05-2012, 05:15 PM
#6 | | Registered User
It wasn't that it's still shakes and it's feel like threw the middle and by my feet and seat it shakes
06-05-2012, 11:55 PM
#7 | | Registered User
Have you checked the trans/motor mounts?
06-06-2012, 10:32 AM
#8 | | Senior Member
| Re: Gears 3.73
Make sure your harmonic balancer outer ring has not slipped or that the hub is not cracked.
Also did you check the driveshaft like I said above?
06-06-2012, 02:49 PM
#9 | | Registered User
No I haven't I just did the tranny bolts haven't had time to check the other stuff would a video help so you guys can hear the differents sounds it makes
06-06-2012, 03:04 PM
#10 | | Senior Member
| Re: Gears 3.73 Quote:
Originally Posted by Jbeas50 No I haven't I just did the tranny bolts haven't had time to check the other stuff would a video help so you guys can hear the differents sounds it makes | It may or may not help. Sometimes sounds make things easy to identify other times it's just really hard to tell.
06-06-2012, 07:00 PM
#11 | | Registered User
Ok well I'll take a video and post it on here see if it does help
