06-04-2012, 07:46 PM
#1 | | Registered User
| t 5 troubles...
Ok. Just got done t 5 swap. Everything seemed ok till I tried goin thru the gears and it was just stuck in 1 gear. So I took the shifter cover off n this is what I see. The 2nd pic is what its suppose to look like. Any advice or how to fix the prob?
06-04-2012, 07:52 PM
#2 | | Senior Member
i have never seen this happen, but im sure someone has. but i would say turn the shaft, so the hole is on top. then try to push it in till it lines up. what i would be worried about is pushing it to far in and not being able to get it back out. but anyways, long story short. line it up and put a new roll pin in it. the roll pin is usually a hair oversize so its tight.
06-04-2012, 07:53 PM
#3 | | Forum Car Trader
Idk what it is but it popped out and turned it looks like the two holes should line up and have some sort of pin in place
__________________ |
06-04-2012, 08:07 PM
#4 | | Registered User
The shaft will only turn a little. Should I try n force it?
06-04-2012, 08:13 PM
#6 | | Forum Car Trader
No.. Wiggle it back and forth don't be forceful until someone else respond that knows more about that and says to.
06-04-2012, 08:15 PM
#7 | | Senior Member
| Quote: |
Originally Posted by 90GTNovi2000 No.. Wiggle it back and forth don't be forceful until someone else respond that knows more about that and says to. | yeah what he said. i forgot to add that important detail. we are just going off mechanical experience, not transmission expertise! or at least me. haha
06-04-2012, 08:16 PM
#8 | | Forum Car Trader
| Quote: |
Originally Posted by dreamstang
yeah what he said. i forgot to add that important detail. we are just going off mechanical experience, not transmission expertise! or at least me. haha | +1
06-04-2012, 08:22 PM
#9 | | Registered User
Yeah. I wiggled it n even tapped on it a little n it will go in just to where that high spot is on the shaft. Almost seems like that spot should be on the other side the housing.
06-04-2012, 08:24 PM
#10 | | Forum Car Trader
Sounds like something behind it isn't correct... Try pushing in the clutch and doing it
#11 | | Registered User
and @ dreamstang. It's stuck in a gear. Moving it in n out doesn't Change that.
06-04-2012, 08:36 PM
#12 | | Senior Member
yeah what 90 said. push the clutch in.,
is the drive shaft on? if it is in gear try rocking the car front and back and see if it free it up in a certain spot so you could get it out of gear.but just a little at a time then pushing the clutch.
06-04-2012, 10:21 PM
#13 | | Senior Member
| Re: t 5 troubles...
You're probably going to have to disassemble the transmission and realign everything. Don't force anything or breakage could occur.
You might try removing it and rolling it on its side and top to try and wiggle the shaft back in, but I'm betting you will have to disassemble it and line up the shifting forks and other parts.
06-05-2012, 02:15 PM
#14 | | Registered User
U gta pull the tranny, u knocked the pin through without it being in 3rd/4th gear?
06-05-2012, 05:17 PM
#15 | | Registered User
Thanks for the help yall. The prob is I just bought it off a guy.  hopefully hell make it right.
06-05-2012, 05:25 PM
#16 | | Senior Member
| Quote: |
Originally Posted by robert3188 Thanks for the help yall. The prob is I just bought it off a guy.  hopefully hell make it right. | bad luck man.
