Transmission Whine - Mustang Evolution
Old 06-05-2012, 08:28 AM   #1
Storm13_5.0's Avatar
Transmission Whine
My tranny whines .. I heard its because my synchronizers are bad is that true ?
Storm13_5.0 is offline   Reply With Quote
Old 06-05-2012, 08:45 AM   #2
Forum Car Trader
90GTNovi2000's Avatar
Doubtful.. Prob low on fluid..
---------- Post added at 08:45 AM ---------- Previous post was at 08:44 AM ----------
I believe the sequencers are for shifting gears... If it happens while driving it sounds like a gear.. Or maybe your rear end is whining
90GTNovi2000 is offline   Reply With Quote
Old 06-05-2012, 11:21 AM   #3
I changed my rear end fluid and I still hear the whining .. It only does it after 35 mph
Old 06-05-2012, 07:14 PM   #4
Did you also use friction modifier?
Old 06-05-2012, 08:45 PM   #5
No what's that?
Old 06-05-2012, 08:47 PM   #6
you are suppose to add it in with the oil. it helps the clutches in the rear end work. that maybe your problem.
Old 06-05-2012, 08:57 PM   #7
Filibuster
Good call 90GT and dream...synchro's shouldn't whine,but low fluid could be a culprit for the trans.and you should add the friction modifier for the rear as that would definitely cause lack of performance and possibly the whine..
XXSTEVEO66 is offline   Reply With Quote
Old 06-05-2012, 09:55 PM   #8
How much goes in?
And the T5 WC uses ATF right ?
Old 06-05-2012, 09:57 PM   #9
4 oz goes in the rear end
Yes atf for a wc t5
Old 06-05-2012, 10:01 PM   #10
Thanks. Any quick tips cuz puttin the fluid in was a PIA ...
An what kind you recommend ?
Old 06-05-2012, 10:04 PM   #11
In trans or rear? Either way, I use a rigged flexible hose on the end of the bottle.
Old 06-05-2012, 10:07 PM   #12
Thanks man!!
I got rid of my EGR all togeather .. Does the smog pump need to go too?
Old 06-06-2012, 08:22 AM   #13
Forum Car Trader
This will save you a big headache $10 at o'rielly's. Just in screw pour fluid in it and pump it out
Old 06-06-2012, 08:38 AM   #14
Man wish I had that a few weeks ago!
But thanks for the tip!!
« Rims | Headers? »
03:12 PM
