1989 mustang not running good need help - Mustang Evolution
Old 06-05-2012, 01:36 PM   #1
kbolden50's Avatar
Start off give you some info on the car it's a 1989 ford mustang started as a 2.3 and swap it for a 5.0 connecting rod bolt broke and cracked the block got a engine out of a 97 explorer with gt40p heads fake cobra intake some upgrades from the 5.0 stock checked the crankshaft end play everything looked good so I change some gasket and seals didn't want leaks the motor starts and runs but not smooth a little shake and I get a small back fire sometimes I did the timing and checked the wires no vac leak I can see or hear going to start it and spray water on the lines to check them want to know where and if you can get your sensor tested And the ECM tested
kbolden50 is offline   Reply With Quote
Old 06-05-2012, 08:43 PM   #2
Re: 1989 mustang not running good need help
Did you use the ECU/ECM from the 5.0?
Wiring harness changed out to the 5.0?
MAF and injectors matched?
The shake and backfire sounds like a timing issue, double check the timing and make sure you wired the plugs correctly to the 5.0 HO 13726548 firing order.
Old 06-06-2012, 11:04 PM   #3
kbolden50's Avatar
I changed wiring and ecm before this engine was in it was my daily driver then the connecting rod bolt broke and cracked the block so I swapped it for this one I wouldn't have to change computers would I
Old 06-07-2012, 07:24 AM   #4
Did you verify the stuff trojan suggested? I'm not sure but if the explorer motor has different injectors and you used the same maf, then that could be a problem.
Also the firing order is different on h.o. and non h.o. this is important because it does sound like timing. Also you removed the spout connector when setting timing, and then remembered to plug it back in?
Also pull the injectors and make sure they look ok. And also you can use a noid light to make sure there firing.
You can also doe a fuel pressure test. Then test you pip and coil. To insure you have proper fuel and spark.
Most of the time the ecu does not fail. It is possible, but usually something else causes it. Like bad connection on salt and pepper shakers, bad ground etc.
Old 06-07-2012, 08:09 AM   #5
thomas91gt's Avatar
Thses salt and pepper shakers are they at the back of the intake
thomas91gt is offline   Reply With Quote
Old 06-07-2012, 08:49 AM   #6
Meansaleen's Avatar
Yes they are by the firewall.
Meansaleen is offline   Reply With Quote
Old 06-07-2012, 09:05 AM   #7
thomas91gt's Avatar
How many are there suposed to be?
Old 06-07-2012, 09:08 AM   #8
There are two of them. The plugs are rather large. Those plugs need to be in good shape. They are known to fail sometimes. especially if they are old. Just unhook them, make sure they are not corroded and all the wires are in the plugs tight.
Old 06-07-2012, 09:12 AM   #9
thomas91gt's Avatar
I thought that was what you were refering to why would i have 4 of these? there is two plugged into the other two lol i thought it looked strange
Old 06-07-2012, 09:13 AM   #10
Well 2 connecting to 2 is right. Sorry if I explained that wrong. 2 connections is what you will have.
Old 06-07-2012, 09:19 AM   #11
thomas91gt's Avatar
O ok sorry to chime in on someone elses post lol
Old 06-07-2012, 01:49 PM   #12
kbolden50's Avatar
I Used the maf I had in the car and I already had it the explorer firing order and HO started with HO but it didn't start and I found out their different I cleaned the s&p connection that what I looked at first. Im going to check wires again and l could I put the explorer coil packs on my mustang if so how
---------- Post added at 07:49 PM ---------- Previous post was at 07:48 PM ----------
Going to check fuel also
1989 mustang
« good deal??? | Cams »
02:18 PM
