Swapping out the AOD - Page 12 - Mustang Evolution
Old 10-16-2012, 04:47 AM   #386
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Ok so I have a question, I was looking at my pressure plate and noticed that it had little grooves in the surface that touches the clutch disc. If you run your fingers around it you can't feel them but if you go top to bottom to can feel them.
Is it still ok to run this pressure plate or should I just try and spring for a new one? Never had any problems with this clutch, pressure plate.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-16-2012, 05:38 AM   #387
04machazblue's Avatar
You could buy a new one, but you can also get yours resurfaced at the machine shop, is this a stock flywheel you are using or aftermarket
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 10-16-2012, 06:16 AM   #388
Well its not good but you aren't having any issues with it and want to make it to the track you can probably run it and make that a winter project. Maybe you can post a pic for us to see?
Btw I still have my stock(?) Clutch setup I changed because I thought it was bad. The problem ended up being my trans. But anyways, its been a while since I looked at it. But if I'm not mistaken it was in great (almost new condition). I would give it to you as long as you pay shipping. If you are interested PM ME.
Old 10-16-2012, 06:27 AM   #389
Pete Jones
Stock flywheel but with aking cobra clutch kit. So the pressure plate is just touching the clutch itself not the flywheel.
---------- Post added at 08:27 AM ---------- Previous post was at 08:24 AM ----------
Kk,I'll Truro get some pics when i get home. The grooves really aren't that deep. Think of a vinyl record that gets scratched up, the grooves aren't depot big enough for anything to fit inside them. To met hey just feel like surface scratches but my buddy said it looked bad but I don't think it's that bad.
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 06:28 AM   #390
Those groves are normal idk why I thought flywheel =p but yes that's normal if there tiny tiny ones but if its burned up to bad or large groves that's not Normal
Old 10-16-2012, 07:47 AM   #391
Lorraine's driver
ab_mach1's Avatar
I guess if the pressure plate fingers look good and the clutch disc isn't really worn looking, it should adjust itself to the new flywheel over some miles. So, the smooth side has grooves?
Edit:
I see your posts about the grooves. I agree, if they aren't big and/or deep, should be okay. If the fingers, where your TOB hits are looking worn, you want to fetch a new one. Probably wouldn't take long to die once that happens.
Instagram: @ab_mach1
Old 10-16-2012, 08:49 AM   #392
Pete Jones
Too bad we don't all live close to each other, then we could get together and have some wrenching parties heh
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 08:57 AM   #393
Lorraine's driver
ab_mach1's Avatar
That would be cool
Old 10-16-2012, 08:59 AM   #394
Pete Jones
Originally Posted by Azure
That would be cool
Then we could fix your car so you wouldn't need a Prius
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 09:07 AM   #395
Lorraine's driver
ab_mach1's Avatar
Ha! Side note, when you put that car in reverse, it would beep like a construction vehicle backing up. The week I had it, I would do that constantly to get on my wife's nerves. Hehe
Old 10-16-2012, 03:41 PM   #396
Pete Jones
Almost forgot to update! Out in the garage right now, flywheel is on, clutch and pressure plate it in, bell housing (the good one) is going on next, then I'm gonna throw the trans up in there. I'm not messin around I'm ready to start this baby up again!!
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 03:44 PM   #397
Pete Jones
Oh, and I got my beer buddy hangin out with me, keepin an eye on things
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 04:03 PM   #398
Filibuster
Sounds like you got everything covered...now a quick question which starter are you using again?..
Ps..Cheers!
XXSTEVEO66 is offline   Reply With Quote
Old 10-16-2012, 04:13 PM   #399
Pete Jones
Gonna throw the aod starter back in, Jegs tech dude said didn't matter which starter manual or auto they would both work
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 04:20 PM   #400
Filibuster
Old 10-16-2012, 04:34 PM   #401
I would use whatever looks the best. The teeth may have wear from engaging on a messed up flywheel. They may not but I would check.
Old 10-16-2012, 04:37 PM   #402
Lorraine's driver
ab_mach1's Avatar
Sweet, glad your gettin it done. to your drinking buddy.
Old 10-16-2012, 05:27 PM   #403
Pete Jones
Burp hiccup!
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 05:31 PM   #404
Pete Jones
Aod starter was in the shorter amount if time compared to the manual one.
Trans is in, driveshaft in in, speedo cable is in, clutch linkage is hooked up. Have to wait till Friday night to button up the rest.
Can you fill the trans up with ATF through the shifter hole? The trans tilted and I kinda sorta forgot to plug the speedo gear hole and it jicked fluid all over me and the floor. I blame my drinkin buddy for not keepin an eye open and these for the mishap! BELLLLLLCCCCHHHHHH!
90 LX hatchback
89 LX Notchback
Old 10-16-2012, 05:44 PM   #405
Lorraine's driver
ab_mach1's Avatar
You can on the TR3650. I would think it would possible on the T5.
Old 10-16-2012, 05:53 PM   #406
Filibuster
Beerzinggg!
Old 10-16-2012, 06:23 PM   #407
Lorraine's driver
ab_mach1's Avatar
Attachment 72501
Old 10-16-2012, 09:24 PM   #408
Looks like he's "dog" tired.
Old 10-17-2012, 04:49 AM   #409
Pete Jones
Lets just say someone left him outside for quite a few hours without realizing he was out there. I just happened to look out the garage window and see him laying there watching the cats play. I'm like what the hell is he doing out there? Needless to say j knew he was out for a couple hours cuz he stink to high heaven lol
90 LX hatchback
89 LX Notchback
Old 10-17-2012, 12:27 PM   #410
That's doggy perfume. We wash it off, they put it back on.
I had a Blue Heeler that was totally devoted to me. He went everywhere with me, even climbing ladders to work on the roof and crawling under the car to work on it. Wasn't to bad unless he had "freshened" up before crawling under the car.
Old 10-17-2012, 03:29 PM   #411
Pete Jones
So how exactly do I wire a relay into my fan switch? Do I just cut and splice one in, what kind of relay do I need? I have my fan hooked up to a toggle switch now so I can turn it on and off but I don't want to burn up the switch because its obviously pulling quite afew amps.
90 LX hatchback
89 LX Notchback
Old 10-17-2012, 03:45 PM   #412
you cant get a fan controller rom summit racing. search fan controller. you can get them adjustable so you can control when you want the fan to kick on. just make sure it comes with a heavy duty relay. mine cost 38$ and came with everything, the controller, water sensor, relay etc.
Old 10-17-2012, 03:50 PM   #413
+1 ^^ What he said.
The electric fans pull a pretty good load on start up (as much as 70 Amps) and can pull as much as 30 Amps when running. They will cook a switch in due time, so be sure to get the HD relay as advised.
Old 10-17-2012, 04:00 PM   #414
Pete Jones
Well I had that fan controller I got from advanced but for whatever reason I could not get it to work correctly for the life of me. Had the 12 volt source spliced into just about every spot I could find, even did the turning if the dial to where it said it should kick the fan on if I turn it all the way one direction which it did not.
I don't know, I would like to get a good controller and have it work properly the first time I wire it in.
90 LX hatchback
89 LX Notchback
Old 10-17-2012, 06:27 PM   #415
Choose your controller, Post the info/wiring diagram suggested for it in another thread (such as "Electric Fan Wiring" so it will be more easily searchable in the forums) and I will help you get it wired correctly.
Old 10-17-2012, 06:52 PM   #416
Pete Jones
Kk, will do.
90 LX hatchback
89 LX Notchback
Old 10-18-2012, 07:42 PM   #417
Pete Jones
Just found out wife has to work Saturday 7am-3:30 which means I need to try and get the car buttoned up Friday night because Saturday night I have to goto a get together we have every year since a good friend passed and celebrate his life.
90 LX hatchback
89 LX Notchback
Old 10-19-2012, 11:20 AM   #418
Pete Jones
It's on like donkey kong when I get home. Now, should I put the shim on the aod starter or leave it off? My 87 had a shim between the starter and bellhousing but my aod did not and the 87 had the factory starter still on it.
Just wondering if I should run it without the shim or not.
90 LX hatchback
89 LX Notchback
Old 10-19-2012, 02:31 PM   #419
Whichever will center up the starter drive gear the best on the flywheel.
Old 10-19-2012, 02:44 PM   #420
Pete Jones
Hmm, gonna be tough to tell. Think I'm gonna try just the starter by itself and cross my fingers. Bout to head out there now.
90 LX hatchback
89 LX Notchback
12:38 PM
