Swapping out the AOD - Page 5 - Mustang Evolution
Old 06-12-2012, 06:36 PM   #141
Re: Swapping out the AOD
Originally Posted by 90mustangLX View Post
Hmm, thought I probed all the empty slots but got no power... I'll have to check again tomorrow.
So would you recommend I crimp a male connector on the end and slide it up into the slot?
Yes, that will work. Just make sure whichever one you use is powered on by the key switch.
Old 06-12-2012, 06:44 PM   #142
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Kk, thanks a bunch TH!
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-14-2012, 03:29 PM   #143
Pete Jones
Ok so I tried to find the number 7 but it isn't getting any power key on or off, even tried number 17 spare, same result
90 LX hatchback
89 LX Notchback
Old 06-14-2012, 03:37 PM   #144
See if you can get a really good picture of your fuse box. Maybe we can identify what you actually have a bit better that way.
Old 06-14-2012, 03:47 PM   #145
Pete Jones
The other 2 wires are for the radio and power to my tach light.
90 LX hatchback
89 LX Notchback
Old 06-14-2012, 04:04 PM   #146
Ok, investigate and probe all of the open holes in the fuse box for power.There is usually always a "spare" or "extra" connection in one or more of them to use for add on accessories.
Failing that you may have to use a switched wire from the ignition switch to power a relay and then feed the power from the battery through a properly sized fuse, then through the relay contacts to your fan control. That will ensure that you do not get low voltage to your control.
Old 06-14-2012, 04:12 PM   #147
87blackonblack's Avatar
From what I know the auto computer will work just fine but a manual computer has a more aggressive timing curve. I want to see how it runs with the auto computer then switch it out with my manual ford racing computer.
I do technically have the manual harness but the one plug in that's under the car must have been sitting on my h pipe because it was toast :/
So if I have to I guess I will just jump the wires so it basically does away with the neutral safety switch altogether. Which I won't mind because that king cobra clutch is a little stiff so the less I have to hold it down the better heh.
---------- Post added at 10:03 PM ---------- Previous post was at 10:02 PM ----------
Yup, southeastern Ohio. Quite a few people on here from Ohio
im from Ohio up between Toledo and cedar point
87blackonblack is offline   Reply With Quote
Old 06-14-2012, 04:59 PM   #148
Pete Jones
To me they feel like dead plugs, when I try to put a regular fuse up inside its like there are no prongs on the inside to hold a fuse
90 LX hatchback
89 LX Notchback
Old 06-14-2012, 06:00 PM   #149
Some of them do not have a fuse holder, they are just a 1/4" blade that you connect with a 1/4" female blade connector. You have to fuse them with an inline fuse.
Old 06-14-2012, 06:09 PM   #150
I found another diagram that is supposed to be from a 1990 5.0 Mustang. It lists 3, 7, 12 & 17 as being spares. One of them should have the connection you need.
Also look down beside the fuses. At times I have found switched connections there too.
You are looking for a flat 1/4" male blade connection.
Old 06-14-2012, 06:10 PM   #151
Pete Jones
K, I poked and prodded with key on and key off, either I wasn't hitting the connectors or they just weren't getting power, I couldn't get the test light to light up :/
I'll try it again tomorrow, I may just unbolt the fuse panel so I can look at it without laying on my back.
90 LX hatchback
89 LX Notchback
Old 06-14-2012, 08:20 PM   #152
That's really strange.
I know my 86 GT has at least two.
Old 06-17-2012, 03:39 PM   #153
Pete Jones
No new update been a little busy this week, I did however find another thermostat housing that I believe came off my 90(think I used the one off my 87 when I swapped intakes) and it has the port for a temp sensor to screw into
ID:	55187   Click image for larger version
90 LX hatchback
89 LX Notchback
Old 06-17-2012, 05:02 PM   #154
thats where i have mine.
Old 06-17-2012, 05:24 PM   #155
Pete Jones
After I found that I looked at the one I used from my 87 and it's just a hole cast into it but it's not drilled, I may swap them out and order the other fan controller that has the screw in probe
90 LX hatchback
89 LX Notchback
Old 06-17-2012, 05:26 PM   #156
i spoke to summit racing when i bought mine. he said either will work, but the actuall screw in sensor would be more accurate.
Old 06-17-2012, 07:03 PM   #157
That's a good cast iron housing.
They are a LOT more accurate.
I have actually used a compression fitting and replaced the brass ring in them with an o-ring or two to install and seal up some of the non immersible temperature sensor probes. As long as you don't clamp down to hard on them and distort the tube they will remain fairly accurate. The only trick is to find the correct size compression fitting.
Old 06-21-2012, 05:38 PM   #158
Pete Jones
Ok so I looked a little closer at my fuse panel. Saw one slot with the little prong you were talking about but it was not getting any power with the key on or off
Didn't get a chance to check out the other spots when I got home because my 2 yr old is running a fever and isn't feeling too hot
90 LX hatchback
89 LX Notchback
Old 06-21-2012, 05:51 PM   #159
Maybe need a better meter/light? Lol j/k
Old 06-21-2012, 05:55 PM   #160
Pete Jones
Could be, it was an advance auto special lol
90 LX hatchback
89 LX Notchback
Old 06-22-2012, 02:49 PM   #161
Pete Jones
Well I think the starter finally bit the dust...... Just got home shut the car off, went inside, opened the garage for went to start the car and you could hear the starter spinning slowly then faster and light grinding....hmmm, guess I'll pull the other starter and add another shim to see if that fixes anything >
90 LX hatchback
89 LX Notchback
Old 06-22-2012, 03:23 PM   #162
that sux man
Old 06-22-2012, 03:46 PM   #163
Pete Jones
Alright, pulled the starter and the one I took out seems to have some in and out play whereas the one out of my 87 does not.
They virtually look the same to me but the one out of my 87 seems to have a slightly larger shaft and shorter distance between the gear and where it would touch the come while engaged.
It also appears that my 90s starter is a remain as it has no ford stamp whereas my 87 is stamped ford on the cone.
Gonna slap the 87 one in and see what it does.
Wish me luck :/
90 LX hatchback
89 LX Notchback
Old 06-22-2012, 03:52 PM   #164
good luck. maybe that was your problem the whole time!
Old 06-22-2012, 03:59 PM   #165
Lorraine's driver
ab_mach1's Avatar
Good luck man!
Instagram: @ab_mach1
Old 06-22-2012, 04:38 PM   #166
Pete Jones
:sigh:........
It's not a starter issue.....it's flywheel
It seems I have a bad spot in my flywheel, I should have just got a new one when I had the chance.... Put the other starter in. Same issue, grabbed a rachet and socket, turned the motor a little hit the key and she fired right up.
I think I'm gonna go throw up now
90 LX hatchback
89 LX Notchback
Old 06-22-2012, 04:44 PM   #167
aww.. that sux!! i feel for ya.
Old 06-22-2012, 04:50 PM   #168
Lorraine's driver
ab_mach1's Avatar
Man, sorry dude. I hope the swap goes smooth.
Old 06-22-2012, 05:20 PM   #169
Pete Jones
That it does.....I kept saying in the back of my mind, you should probably just get a new flywheel, then I said well I already have a flywheel so that will save me some cash because I was thinking the other starter was just on its way out.
Well, I think I'm just gonna enjoy the car this summer then in the winter tear back into it a throw a new flywheel in it. I would do it now but it's so flippin muggy and hot right now I don't want to mess with it lol.
I guess I'll just chalk this one up to experience. Next time(of there is one) buy a new flywheel and play it safe, go with the gut feeling. So now I know if it won't turn over I need to crank the engine by hand a little and shell fire right up, at least until the rest of the flywheel wears out on me :/
---------- Post added at 07:20 PM ---------- Previous post was at 06:53 PM ----------
I do have one question, I'm thinking about switching my a9p computer for my ford racing a9s computer. Is there anything special I need to do timing wise? I know the manual computers have a more aggressive timing curve.
Also for the first time I've had my car out I can stomp the gas, spin a little then it pulls like hell, throw it into second and spin a little more and pull like hell. It actually surprised me how much pull it has now compared to when the auto was in there. I honestly think if I can get it to hook up I might be able to push a high 13.
Probably wishful thinking but it will definately be in the 14s compared to my 15.1 run with the junk aod heh.
90 LX hatchback
89 LX Notchback
Old 06-22-2012, 05:21 PM   #170
I would just keep a spare wrench with you so you don't get stranded.
Old 06-22-2012, 07:44 PM   #171
Start with your timing set to the factory 10° BTDC when you swap computers. Then if everything is ok you can advance it from there. 14° or 4° advance seems to be the most beneficial timing advancement, but you will probably need to run premium fuel to keep it from detonating.
Old 06-28-2012, 06:23 PM   #172
Pete Jones
Haven't had a chance to do anything else to the car, been working longer hours at work and then getting prepared for my 3rd child to be born this Saturday.
Gotta make sure I have everything ready heh. So I pretty much have all of next week off, maybe once everyone is napping I can sneak out in the garage and do a little tinkering like swapping the computers and testing the fuse box prongs again lol.
90 LX hatchback
89 LX Notchback
Old 06-28-2012, 07:14 PM   #173
thats awsome man. i cant wait to congratulate you.
and when they fall asleep for a nap. just make sure you can hear the ol lady yell for yeah! or she will be pi$$ed at you and your stang.
Old 06-28-2012, 07:28 PM   #174
Pete Jones
Oh yeah no doubt, she'll probably be mad if I'm out there no matter what lol. Surprised she didn't say anything when I was doing my 5 speed swap heh.
90 LX hatchback
89 LX Notchback
Old 07-02-2012, 08:45 PM   #175
Pete Jones
Meh, still no update, been humid and hot as hell. Been without power since Friday nights storm rolled through :/
Praying it comes back on soon so I don't have to keep buying gas for the generator.
90 LX hatchback
89 LX Notchback
05:29 AM
