Swapping out the AOD - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Old 06-05-2012, 06:17 PM   #1
Pete Jones
90mustangLX's Avatar
90mustangLX is unknown around these parts
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Alright fellas, I'm starting my 5 speed swap. I already have everything I need(I think) to complete it.
Just got done pulling my aod about a half hour ago and it wasn't too bad.
Now, are there any tips or tricks I need to use when swapping in my t-5? I was told by a buddy I needed to swap in a harness from the donor car(the one with the 2 studs sticking out) because it has the neutral safety switch in it but from what I've read they all gave the neutral safety switch already in them.
Or is the 2 prong on the manual part of the neutral switch? If that's the case I can't save it....looks to have been laying on a h pipe :/
ID:	53414   Click image for larger version
90 LX 5spd swap Stock 302 GT40P heads
BBK shorties and h-pipe
flowmaster 40's dumped, Jegs Big n Littles
BBK CAI, BBK SSI-R upper and lower
Professional Products 75mm TB,Electric Fan
MSD 8.5 90 degree plug wires
90mustangLX is offline   Reply With Quote
Old 06-05-2012, 06:23 PM   #2
Senior Member
dreamstang is unknown around these parts
I don't know about the neutral saflety switch. But the harness for the reverse lights may need swapped.
Old 06-05-2012, 06:32 PM   #3
Pete Jones
Eh, I'm not too worried about reverse lights, if it comes down to it I'll have to find another car as I believe that's the wire that's toasted :/
Now can anyone tell me exactly what these are for?
ID:	53417   Click image for larger version
Old 06-05-2012, 07:28 PM   #4
WhiteCobra94's Avatar
WhiteCobra94 is unknown around these parts
I don't want to go off topic but I was thinking down the road swapping out my built aod-e to 5 or 6 speed , what's everything I need from trans to mounts , different radiator ......
Old 06-05-2012, 07:29 PM   #5
Senior Member
I actually wouldn't mind knowing that also. Cause mone are not in use. Lol
Old 06-05-2012, 07:33 PM   #6
Pete Jones
Flywheel, clutch, pressure plate, throw out bearing, pilot bearing, trans, crossmember(read you can modify the auto xmember to work), 5 speed pedal assembly, clutch cable and possibly wiring for the neutral safety switch or you can do what I might do and that's to bypass it.
I think you can reuse your radiator but may need to block off the trans lines on it.
Old 06-05-2012, 07:39 PM   #7
Sweet thanks!!!
Old 06-06-2012, 10:22 AM   #8
Pete Jones
Hey dream stang, you wouldn't happen to know how much ATF the t5 takes do you?
Old 06-06-2012, 10:24 AM   #9
Senior Member
If I remember correctly about 2.8 quarts.
Old 06-06-2012, 11:01 AM   #10
Pete Jones
Kk, thanks, debating on filling it up before or after I wrestle it in there.
Old 06-06-2012, 11:03 AM   #11
Senior Member
I heard some guys fill it up through the shifter whole. I always fill it first then tape a bag around the tailshaft very good. I only loose a little bit, and I have done it quiylte a few times.
Old 06-06-2012, 01:00 PM   #12
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
I have an old driveshaft we cut it down and when we pull trannys we just slide it in the tail shaft and a lil tape it works great
90GTNovi2000 is offline   Reply With Quote
Old 06-06-2012, 01:04 PM   #13
Forum Car Trader
Get one of these from o'rielly's it's a fluid pump you just un screw the top pour your fluid in and pump it out
Old 06-06-2012, 02:52 PM   #14
Senior Member
Trojan Horse is just getting started.
Re: Swapping out the AOD
Just FYI, they make plastic "plugs" just for that purpose. A whole set of different sizes is $10-$15
Old 06-06-2012, 02:56 PM   #15
Forum Car Trader
Lol.. I've seen them before.. We just use our southern engineering
Old 06-06-2012, 02:56 PM   #16
Senior Member
Haha. That's it! Lol
Old 06-06-2012, 03:17 PM   #17
Senior Member
Well, me too until the "duck tape" I was using let go and dropped about a pint or two of fluid in my face. That stuff doesn't taste very good ya' know, so I had no desire for a repeat performance so to speak.
Old 06-06-2012, 04:01 PM   #18
Forum Car Trader
lol
Old 06-06-2012, 04:28 PM   #19
Filibuster
XXSTEVEO66 is unknown around these parts
Lol!...I used to work at jiffy lube in high school did plenty of trans pans and drain n fills and sure I drank a few quarts in the process:/ BWAH!..the burnt brown is the worst I prefer fresh fluid...shaken never stirred!..lol
XXSTEVEO66 is offline   Reply With Quote
Old 06-06-2012, 04:32 PM   #20
Forum Car Trader
+1 except I worked at American Transmission doing R&R oil changes and brakes.. No more of that pay suck to sweat balls in a non ac shop
Old 06-06-2012, 04:50 PM   #21
Pete Jones
I actually just took the yoke off my other driveshaft and slid it on, worked like a charm but I didn't take into account the dipstick tube a d when I pulled it it gushed ATF all over the floor.
Oh well, guess that's why they make absorbent
Got a new trans mount, pilot bearing, alignment tool and some blue thread locker, gonna see if I can get some more done tonight unless the wife is grumpy :S
Old 06-06-2012, 04:54 PM   #22
Senior Member
for some reason i can never do anything on my car without getting oil on the floor. it never fail
Old 06-06-2012, 04:54 PM   #23
Forum Car Trader
I bet you can hear her now... "are you going to stay out there all night?"
What I usually say is.. No just until I'm done!!
Old 06-06-2012, 04:59 PM   #24
Pete Jones
I usually just say "give me a minute" which turns into a half hour or more, that really gets her going
On another note, should I put a little grease around and behind the pilot bearing before I put it in?
Old 06-06-2012, 05:00 PM   #25
Senior Member
I usuall add grease
Old 06-06-2012, 05:19 PM   #26
Filibuster
I did..and a bit inside also but didn't overkill it with grease to avoid it spooging on the pressure plate..
Old 06-06-2012, 07:14 PM   #27
Pete Jones
Alright, pilot bearing in, flywheel on, clutch and pressure plate on, bellhousing with fork on, clutch cable ran.
Having a bit of trouble with the auto shifter, I have the 4 screws out. Won't come out.....do I need to remove the center console? Thought I read it could be taken out with it intact but the arm on the bottom of the shifter seems to be in the way...
Old 06-06-2012, 07:44 PM   #28
Senior Member
You need to pull the console and trim a little metal away to make the fit better.
Old 06-06-2012, 07:46 PM   #29
Pete Jones
Well I mean getting the aod shifter out. I did read about trimming the doghouse. Just seems it doesn't want to come out. I'll take the console apart tomorrow if the wife allows it.....she looked pretty pissed when I came in tonight heh.
Old 06-06-2012, 07:50 PM   #30
Senior Member
well you have to keep the wife happy. sometimes i take a break for a day or two just to keep her happy.
Old 06-06-2012, 08:07 PM   #31
Senior Member
Women are never happy. My wife was just the same as all of yours. Now that I'm damaged goods and unable to get out and do much she wishes I could.
So tell yours to be careful what she wishes for, cause you know someone who's wife wished the same and now that it came true, it's not quite what she had in mind.
Old 06-06-2012, 08:22 PM   #32
Senior Member
lol. but one day may her new wish be answered and you can get your butt back at it!
Old 06-06-2012, 08:29 PM   #33
Forum Car Trader
Hell yeah I wanna see TH's car and watch the progress...
Old 06-06-2012, 08:36 PM   #34
Pete Jones
+1000000000 I wanna see TH's car up and running with him behind the wheel chirpin gears and doing donuts!
Old 06-06-2012, 08:38 PM   #35
Senior Member
if he doent get healed. we are gonna have to plan a weekend and all meet at trojans house. and have a mustang building party. but im sure that he likes others wrenching on his vehicles.
01:55 AM
