coyote in a fox - Mustang Evolution
Old 06-06-2012, 03:42 PM   #1
87lx's Avatar
Region: Nevada
coyote in a fox
Has anyone here successfully done this? what was the total cost? Was it worth it or would dumping the money into a 302-351 be more practical
87lx is offline   Reply With Quote
Old 06-06-2012, 03:45 PM   #2
It's not me, it's you.
primer2tone's Avatar
It would be hella expensive to swap a coyote into a fox but it would be sweet if you've got the cash. I've got an '88 Bronco II I'm seriously thinking about dropping a roadrunner (Boss) into it.
Old 06-06-2012, 03:46 PM   #3
5.0 magazine did one about 10grand
tbonestang is offline   Reply With Quote
Old 06-06-2012, 03:48 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
That would be completely badass!! I don't know what it would cost but I would definitely love to see the end result
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-06-2012, 04:07 PM   #5
DO IT!
Old 06-06-2012, 04:27 PM   #6
87lx's Avatar
Region: Nevada
Talking Re: coyote in a fox
I don't have 10 grand but was thinking i could put it together in time searching the wrecking yards. i know its a bad though but i know some will get totaled in a wreck but still have good parts for much less than new. i have a 87 lx and i think that would be strong in a light fox
Old 06-06-2012, 04:29 PM   #7
it would be real strong. even a wrecked one with a good motor is still gonna cost alot. but if you keep looking i assume that you will eventually find a deal.
Old 06-06-2012, 04:39 PM   #8
87lx's Avatar
Region: Nevada
Re: coyote in a fox
Anyone know what the difference in weight between the new and old 5.0 is
---------- Post added at 04:39 PM ---------- Previous post was at 04:33 PM ----------
Anyone know what the difference in weight between the new and old 5.0 is. coyote and tranny vs old 5.0 and a t5
Old 06-06-2012, 04:46 PM   #9
Wish I got the guys contact info from Sebring with the coyote fox
Old 06-06-2012, 04:56 PM   #10
87lx's Avatar
Region: Nevada
Re: coyote in a fox
Yeah. i bet it was nice. did u get to see it run. beautiful ride by the way
Old 06-06-2012, 04:57 PM   #11
Yeah he had it on the track a few times.. He also won the car show hands down...
Old 06-06-2012, 05:04 PM   #12
87lx's Avatar
Region: Nevada
Re: coyote in a fox
I'll have pics of mine up soon
---------- Post added at 05:04 PM ---------- Previous post was at 05:01 PM ----------
Dumb question but how did it do. Did it handle well. was it stock
Old 06-06-2012, 05:32 PM   #13
Re: coyote in a fox
Coyote Engine Specs if you need them.
5.0 4V TiVCT V-8
First Model Year 2011
Engine Family Modular
Code Name: Coyote
Displacement 4957cc (302 ci)
Bore x Stroke 92.2 x 92.8mm (3.263 x 3.647 inch)
Horsepower
412 hp @ 6,500 rpm, 91 octane
402 hp @ 6,500 rpm, 87 octane
Torque
390 lb-ft @ 4,250 rpm, 91 octane
377 lb-ft @ 4,250 rpm, 87 octane
Shipping Weight 430 pounds, includes water pump
Block Low-pressure cast 319 aluminum, pressed-in thin-wall iron liners
Bore Spacing 100mm (3.937-inch)
Deck Height 227mm (8.937-inch)
Deck Thickness 13mm (0.510-inch)
Cylinder Head Retention 12mm bolts, 4 per cylinder, 10 bolts total per bank
Oil 5W/20 weight, mineral
Oil Pan Stamped steel, 8 quarts
Windage Tray Integral w/oil pan gasket
Oil Pump Gerotor
Pistons Hypereutectic, short-skirt, flat-top w/four equal valve reliefs; moly friction-reducing coating; oil-jet cooled
Piston weight 500 grams
Piston Pin Full-floating, 22mm diameter
Piston Pin Retention Wire lock
Piston Rings 1.2 x 1.2 x 2.5 mm, moly top ring
Connecting Rod Powered metal forging, I-beam, no balance pad
Connecting Rod Length 150.7mm (5.933-inch)
Rod/Stroke Ratio 1.62
Crankshaft Forged steel, fully counterweighted, induction hardened
Main Journal 67.5mm (2.652-inch) diameter
Rod Journal 53.0mm (2.082-inch) diameter
Flywheel Retention Eight-bolt
Cylinder Heads Aluminum, four-valve per cylinder
Head Bolts 12mm, four per cylinder
Valve Covers Composite
Compression ratio 11.0:1
Valves 37 x 31mm (1.454 x 1.218-inch), four per cylinder
Camshafts DOHC, four camshafts, independently adjustable timing
Camshaft Timing Twin independent variable
Duration 260 degrees intake, 263 degrees exhaust
Lift 12mm (0.472-inch) intake, 11mm (0.432-inch) exhaust
Lift Limit 13mm (0.510-inch) physical limit in head
Valve Followers Roller-finger follower
Lash Adjusters Hydraulic
Coolant Organic (red)
Exhaust Manifold Short-tube, S44100 stainless-steel Tri-Y tubular headers; 10mm mounting studs w/prevailing torque nuts
Intake Manifold Constant cross section, long-runner single-plane (single-scroll); molded composite w/upper section colored; front throttle body mount
Throttle Body Single-blade, 80mm, e-throttle
Engine Management Software Copperhead
Mass Air Meter 86mm, digital
Oxygen Sensors Universal Exhaust Gas
Knock Sensors Two, in block valley
Ignition Timing Crank trigger, rear of crankshaft
Ignition Coil-on plug
Spark Plug NGK Iridium
Firing Order 1 5 4 8 6 3 7 2
Cylinder Numbering
Right bank: 1, 2, 3, 4
Left bank: 5, 6, 7, 8
Fuel System Port fuel injection, returnless
Fuel Injectors 32.8-lb/hr
Fuel Pressure 55 psi
Fuel Requirement 87 octane minimum, 91 octane best/rated power
Old 06-06-2012, 05:42 PM   #14
87lx's Avatar
Region: Nevada
Dam. Thanks that's awesome
Old 06-06-2012, 09:44 PM   #15
87lx's Avatar
Region: Nevada
Ha i figured out how to add pics. Not easy on this phone
Old 06-17-2012, 07:11 AM   #16
Re: coyote in a fox
93Coupe.com - My 93 Coyote 5.0 Boss 302 Mustang Coupe build. Sebring coupe
StangNet 'Built to Cruise' Project - StangNet
High Flow Performance
Great write ups on coyote swaps. Doing a coyote swap in my 87 Coupe in the near future.
Wahoo is offline   Reply With Quote
Old 06-17-2012, 10:41 AM   #17
Re: coyote in a fox
Thanks for the links.
Note: Anyone doing a swap, if you have time and would like to document and take pics of the procedures you go through with your swap, we could use a good article on it.
No pay, but you would have the appreciation and gratitude of people doing the same swap later on.
03:33 AM
