Rear end shifting - Mustang Evolution
Old 06-06-2012, 03:59 PM   #1
93_347foxbody's Avatar
Rear end shifting
alright whenever i put the pedal to the floor or even a little more than halfway my rear shifts and i hear a knock from the back. or when i down shift into 1st or 2nd. i thought this was maybe because my torque box was beat up but a few people told me that wouldnt be the issue. what causes rear ends to shift like this?
---------- Post added at 05:59 PM ---------- Previous post was at 05:58 PM ----------
and when i down shift or let off the gas i can feel my shifter move as if the whole trannys turning
93_347foxbody is offline   Reply With Quote
Old 06-06-2012, 04:14 PM   #2
make sure the bolts are tight on the trans and the crossmember is in place properly.
i dont know for sure. but if the torque boxes are in the proccess of ripping out, i could see movement.
---------- Post added at 05:14 PM ---------- Previous post was at 05:09 PM ----------
also check your motor mounts
Old 06-06-2012, 05:08 PM   #3
Re: Rear end shifting
Make sure the bushings in the rear control arms are not pounded out too.
Old 06-06-2012, 07:51 PM   #4
Are you supposed to be able to see the rubber when you look at the ends of the control arms?
Old 06-06-2012, 07:57 PM   #5
here i found a pic of what it should look like normally
Old 06-06-2012, 08:06 PM   #6
i cant really tell too much mine doesnt look messed up now that i look more is it obvious when the bushings go? like from thet outside looking at it
Old 06-06-2012, 08:28 PM   #7
your probably just gonna have to make a judgment call on that. if they look ok they probably are. maybe take a small pry bar and see if you can move the arm back and forth alot?
04:54 AM
