Clutch - Mustang Evolution
Old 06-06-2012, 04:43 PM   #1
Sprague199's Avatar
Clutch
As wondering if I need new clutch I have 87 gt the clutch let's out about 5-6 inches from floor and sometimes first gear grinds but don't feel slipping when I drive it
Sprague199 is offline   Reply With Quote
Old 06-06-2012, 04:45 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
Doubtful.. Maybe a new synchro and a lil adjustment but that sounds about normal for a fox clutch
90GTNovi2000 is offline   Reply With Quote
Old 06-06-2012, 04:49 PM   #3
Sprague199's Avatar
I was lookin into it can you adjust the clutch on that ?
Old 06-06-2012, 04:51 PM   #4
Forum Car Trader
Why not?
---------- Post added at 05:51 PM ---------- Previous post was at 05:50 PM ----------
It's on the firewall.. You may need a hand if you have never done that.. It's not my expertise so I will let dream Steve or TH take it from here
Old 06-06-2012, 04:53 PM   #5
Sprague199's Avatar
Idk I'm not to experienced with clutches how do you adjust it ?
Old 06-06-2012, 04:55 PM   #6
Forum Car Trader
You honestly just turn it but wait for someone else to give more details
Old 06-06-2012, 05:15 PM   #7
Filibuster
The clutch should engage about 1-2 inches of the floor...if you have a firewall adjuster that is where you can take the slack out,or at the clutch fork it can be adjusted...this is of course if you have an adjustable cable...or if you have the stock quadrant pulling up on the clutch adjusts the quadrant to clear up some slack
---------- Post added at 06:15 PM ---------- Previous post was at 06:05 PM ----------
My cable adjusts at the clutch fork...if you look under your car where the cable attaches to the trans you'll see a threaded rod with two nuts that can be adjusted...and if you have the firewall adjuster the its right on the firewall under the hood where the clutch cable comes from the cab...if neither is there then you have a stock cable and most likely a stock ”self adjusting quadrant”
XXSTEVEO66 is offline   Reply With Quote
Old 06-06-2012, 06:05 PM   #8
Sprague199's Avatar
Ok thanks
Old 06-06-2012, 08:47 PM   #9
Good info.
Old 06-10-2012, 12:13 AM   #10
Re: Clutch
Originally Posted by dreamstang View Post
Good info.
Indeed, very good info Steve. You covered every scenario.
11:38 PM
