lil help - Mustang Evolution
Old 06-06-2012, 10:01 PM   #1
thomas91gt's Avatar
lil help
What kind of symptoms does a lower intake gasket leak have.. between the intake and head
thomas91gt is offline   Reply With Quote
Old 06-07-2012, 03:06 PM   #2
You could have a miss or a water leak. You can spray carb cleaner around the intake and see if your idle changes to help find that kind of leak. Be careful of paint and electronics.
Old 06-08-2012, 06:02 AM   #3
thomas91gt's Avatar
Do you think it would get better after a few mins of driving.. But even then still have no power guess im just gonna go for it and put new gaskests on all of it i found a tubular gt40 intake that i wanna put on it anyways and i need valve cover gaskets to what do u think is the bigest came i can use with a stock aod and stock torqe converter
Old 06-08-2012, 06:14 AM   #4
Forum Car Trader
90GTNovi2000's Avatar
Don't worry about a huge cam just stay conservative and get a cam with a choppy lope.. If you put a big *** cam in there it could get even slower... You want the right combo..
90GTNovi2000 is offline   Reply With Quote
Old 06-08-2012, 11:00 AM   #5
garbill2003's Avatar
E303 and b303 are good mid range cams
garbill2003 is offline   Reply With Quote
Old 06-08-2012, 01:34 PM   #6
aegischief's Avatar
I wouldn't go bigger than a E303 or something similar on a stock motor.
Usually you put in a cam after mods are done to round out and maximize the combo. The best specs for a N/A motor would need to be different than that of a nitrous or forced induction motor.
Stay conservative if you gotta change it out. Personally, I'd would wait on the cam till you are ready to change the heads and intake as well.
aegischief is offline   Reply With Quote
» Members Mustangs
Roxie
ashpow24
silvia
Smoke
Add your Mustang
09:37 AM
