Got the first piece - Mustang Evolution
Old 06-06-2012, 10:13 PM   #1
89Saleen141's Avatar
Got the first piece
So I finally got my 130 amp alternator. Now, what else do i need in order to install it into my car? I read that I would need to modify the alternator bracket and purchase some 4 gauge wire for the alternator cause the stock wire won't do.
89Saleen141 is offline   Reply With Quote
Old 06-06-2012, 11:28 PM   #2
SleepingStang's Avatar
Easiest way is to order the wiring kit from PA Performance. Otherwise you need 4 GA positive and ground wires. Ground wires are just important as positive wires. You will need one of the following: maxi fuse and holder, waffle style fuse and holder or a circuit breaker. Personally I like the circuit breakers in case of a fault it is just a reset button and not a $5 fuse. Also look online for the modification needed to the stock alternator wiring harness, it is quite simple. The modification to the alt bracket is straight forward if you have a dremel tool or some type of due grinder. You will really notice a difference if you have stereo or other equipment drawing power. Good luck.
SleepingStang is offline   Reply With Quote
Old 06-07-2012, 05:38 AM   #3
Forum Car Trader
90GTNovi2000's Avatar
What I did was go to the junkyard and take the lead from a 95+ mustang.. It will take place of the current lead that is 6 gauge
90GTNovi2000 is offline   Reply With Quote
Old 06-07-2012, 06:36 AM   #4
Stang.racr's Avatar
You'll need s hela coil too
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-07-2012, 11:08 AM   #5
Re: Got the first piece
So I am about to order the PA performance power wire kit. Do I also need a voltage regultor or rectifier/alternator plug?
Old 06-07-2012, 11:45 AM   #6
Stang.racr's Avatar
You will reuse one of your plugs and the other one will need to be altered alittle
Old 06-07-2012, 12:54 PM   #7
So all i need to really buy is the Wiring?
Old 06-08-2012, 03:57 PM   #8
Yes just buy the wiring kit. The plugs you need for the alternator are already in the car. 1 will just plug on and the other needs alteration then it will plug on. The alternator should already have the voltage regulator on it. PA Performance's website has the install instruction I believe. Otherwise do a search on the swap and I'm sure you'll find numerous posts on the wiring change.
Old 06-09-2012, 01:33 PM   #9
Thanks a bunch, I'll post up pictures of the process while i'm going through it. So I don't need to alter the wiring harness at all? And a die grinder will work fine with the bracket alteration?
Old 06-10-2012, 01:18 AM   #10
Lots of diagrams and instructions.
3G Alternator Install
11:47 PM
