Need Help! - Mustang Evolution
Old 06-08-2012, 11:51 AM   #1
Mrsjnsn's Avatar
Region: Nebraska
Exclamation Need Help!
I have a 94 mustang gt, and it keeps dying on me. My husband is a really good mechanic, but mostly works on Chevys, so he's kind of stumped on this. We have replaced the ignition module, the distributer cap and all spark plug wires. He says it's definitely not the fuel pump.
She only wants to run when she's cool. I drove her a couple miles and she died last night. Wouldn't start again. Husband says she has "no ignition". If anyone has any suggestions, it would be greatly appreciated! Thanks!
Mrsjnsn is offline   Reply With Quote
Old 06-08-2012, 12:00 PM   #2
87blackonblack's Avatar
Check your coil!
87blackonblack is offline   Reply With Quote
Old 06-08-2012, 12:24 PM   #3
Storm13_5.0's Avatar
Originally Posted by 87blackonblack
Check your coil!
^+1
Storm13_5.0 is offline   Reply With Quote
Old 06-08-2012, 01:31 PM   #4
93slowstang's Avatar
It is more than likely the TFI module, highly doubt it's the coil.
Old 06-08-2012, 04:44 PM   #5
i believe somewhere in the stickys there is a procesure to test the tfi module. this can probably also be found in your haynes/chilton book
Old 06-08-2012, 09:39 PM   #6
Mrsjnsn's Avatar
Region: Nebraska
Thanks for the help! I guess the TFI module is what we replaced last night, so it's on to the coil. Great feedback!
Old 06-08-2012, 11:03 PM   #7
let us know Good luck
Old 06-09-2012, 05:19 PM   #8
Mrsjnsn's Avatar
Region: Nebraska
Unhappy Re: Need Help!
Ok, we replaced the coil, and it still won't run. Any other ideas?
Old 06-09-2012, 05:55 PM   #9
do u have spark at all?
Old 06-10-2012, 12:22 AM   #10
95GTvert's Avatar
I had the same issue 2 different times 2 different problems, first time it was the "coil pick up" if you order it through the parts store that's what they call it, just the wiring from coil to distributor. But you will need to tear down the, distributor fully to replace because it slides around the shaft. Fixed my problem first time....next time was a month later, thought it was fuel pump because I couldn't hear it,humming and no fuel...but after testing it it was fine...the problem was actually a,simple fix of dirt and grime in the connection to the top of the pump, cleaned it and got a good connection, haven't had the problems anymore 7 months later. Hope it helps.
95GTvert is offline   Reply With Quote
Old 06-10-2012, 01:46 AM   #11
Re: Need Help!
The PIP would be my recommendation too.
They act up just like you are describing. Run fine when cold, won't run when hot.
Old 06-10-2012, 09:45 AM   #12
Mrsjnsn's Avatar
Region: Nebraska
No spark
Old 06-10-2012, 12:28 PM   #13
+1 PIP. Pull the distributor and check the wheel too.
1fst86 is offline   Reply With Quote
Old 06-10-2012, 01:56 PM   #14
Re: Need Help!
P.S. If the engine has a lot of miles on it you may be better off replacing the entire distributor as it is likely worn out anyways.
03:04 AM
